Question about Acomdata PHOTON 2.5 (PHD080U2E54) Hard Drive
Acomdata Photon 2.5 80GB 5400RPM USB 2.0 drive on Vista OS
On my new HP desktop with Vista it is not recognized at all.
On my new Toshiba laptop with Vista it keeps giving I/O errors regularly. Du eto this I am not able to transfer files on this device.
Do I need to find Vista drivers for this device? If so from where and how to install it. Have not been successful in finding one.
PauldLucky
  • 268 Answers
SOURCE: Acomdata external hard drive
No ned to check in that.
The external hard drive can be fomatted by :
Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
Right click on the drive you will get the popup menu.
In that select the format option.
But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
Use the full format option.
Wait for sometime, until the format is completed.
Then you are good to go.
Good Luck.
Live, Love, Laugh.
Posted on May 09, 2008
SOURCE: External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Posted on Aug 29, 2008
SOURCE: ACOMDATA HD080U2FE-72 External Hard Drive
my final solution was to remove the drive from the housing and install it as a slave in the main case. The computer is operating Windows XP and instantly recognised the drive. Works fine, all of my data is there. No problem now. This approach will not help laptop users but they might try removing the drive from the ACOMDATA housing and installing it in another housing.
redrippervf1
Posted on Sep 17, 2008
  • 408 Answers
SOURCE: The red light is staying on on my Acomdata 1TB
I would say take the drive out and if you have SATA connectors on your motherboard, connect it directly to you computer and see if the computer will recognize it.  If it does, your enclosure is bad.
Posted on Mar 04, 2009
  • 3 Answers
SOURCE: acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Posted on Apr 21, 2009
Where can I find systems tray
On the main screen where you have all the apps there will be a tile with desktop written on it if you click on it it will give you the regular desktop screen similar to to win 7 ,vista.
Feb 14, 2013 | Toshiba Computers & Internet
My toshiba laptop was recently swiped clean and rebooted running vista. Everything was running smooth.until i shut down the system. the next time at start up it didn't recognize any OS. the next t
I recommend reinstalling Vista, and replacing the Hard Drive as well. The errors being sporadic could be indicative of a hardware failure or a software failure and could be both in tandem.
Dec 09, 2012 | Toshiba Computers & Internet
Vista laptop recognizes HP printer but won't print
Make sure the usb cable between the laptop and printer hasn't come loose. That's usually what happens when when the cable isn't sitting in the slot properly
Sep 22, 2009 | Toshiba Satellite A355-S6925 Notebook
Can I put vista that was on a toshiba laptop on a hp desktop? the laptop is squashed and can't be used, I own the license for it...
No , You cannot install Vista on HP desktop that is on Toshiba Laptop, Even if you have license. Your HP won't accept the vista disk.
Sep 07, 2009 | Microsoft Windows Vista Home Premium with...
Toshiba Laptop is having trouble booting up.
hi,
Please reinstall vista once.If the issue is not fixed this seems an issue with HDD
Jul 14, 2009 | Computers & Internet
Ok for resolve this blue problem
Mon français est horrible, mais je tente. Mes excuses pour la mauvaise langue.
Si votre problème est ce que je pense, ensuite vous avez essayé de télécharger et d'installer
Mise à jour du micrologiciel pour disque DVD-R/RW HL-DT-ST GSA-H20L "HP portable HP Pavilion dv2899ef
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-68058-1&lc=en&dlc=en&cc=us&os=2093&product=3311651
Si vous ne pouvez pas supprimer et redémarrer votre ordinateur, puis ajouter ce disque à réparer ...
Ensuite, vous aurez besoin de quelqu'un qui peut regarder le problème de physique (en personne) à régler.
May 07, 2009 | Computers & Internet
Toshiba satellite E100ยป laptop and HP laserjet 3030 printer
Check the HP website and see if there are Vista drivers for your model. If you installed them from the disk they're likely not compatible.
Apr 27, 2009 | Toshiba Computers & Internet
Just purchased the kinsington bluetooth micro adapter. Vista loads the Toshiba Bluetooth stack software, but will not recognize the adapter (dongle) when I insert it. I have tried other usb ports and...
It is possible that the adaptor is not compatible with your version of windows vista, despite what the system requirements for the device say.
Below is a link where you can download the latest driver for your bluetooth adaptor. Support XP sp1, sp2, and vista. Try this driver
http://update.broadcom.com/downloads/btwinitialupdate.exe.
Apr 19, 2008 | Computers & Internet
Acomdata PHOTON 2.5 (PHD080U2E54) Hard Drive Logo
59 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
