Question about Fusion 10" Single-Voice-Coil 4-Ohm Marine Subwoofer
Cu Ft for Sub
What is the volume needed for a 12'' Fusion?
There isnt a product selection about it, so i had to put it under a different category brand.
Thank you
  • 15,935 Answers
EN-SW100 EN-SW120 EN-SW150
PORTED
Volume (litres) 28.5 48.28 91.28
Volume (cuft) 1.008 1.705 3.223
Port diameter 76.2mm / 3" 76.2mm / 3" 101.6mm / 4"
Port length 255mm / 10" 225.3mm / 8-9/10" 242.5mm / 9-1/2"
Tuned frequency (Hz) 41.6 33.0 34.2 SEALED
Volume (litres) 15.71 28.58 85.53
Volume (cuft) 0.56 1.009 3.02
Tuned frequency (Hz) 69.9 53.9 44.4
If this doesnt come out right, look at the following link...
http://www.fusioncaraudio.com/north-and-south-america/suggested+encounter+subwoofer+enclosures+sizes-12-technical-support-detail.aspx
Posted on Jan 08, 2009
Where can I download Danny service manuals
Support - Danby
www.danby.com/en-us/support/
DanbyProduct Registration Product Support & Manuals Find Parts .... Product Manuals. Select Product Category. All. Microwaves. Washing Machines ... Service Depots ..
Oct 29, 2015 | Danby DFF261WDB 9.2 Cu. Ft. Apartment Size...
How many square feet are in 2700 cubic feet
You should review the difference between the concept of an
area
and that of a volume. The confusion can create a lot of headaches for you.
To determine how many boards can fit in a volume of
2700 cubic feet, you must first calculate the volume of a
single board, then divide 2700 cu. ft. by the value of the
volume of a board.
Convert inches to feet.
1 ft = 12 in, thus 1in =(1/12) ft=
Volume of a board = length *width*height=
(2.25/12)*(48.00/12)*(108.00/12)= ? cu. feet
Divide 2700 cu. ft. by the value ( ? cu. ft. ) you find as
a result of the calculation above.
I trust you can do that on your own.
Sep 11, 2014 | Office Equipment & Supplies
How many cubic yards of material are needed for the foundation of a barn 40 by 80 ft., if the foundation is 2 ft, thick and 12 ft. high?
I'm sorry to tell you but it's actually wrong..
this should be how it drawn..to solved this two volume is needed..the outside and inside volume..12_5_2012_12_36_29_am.gif
V(outside)=80(40)(12)
V(outside)=38 400 cub. ft.
V(inside)=(80-2-2)(40-2-2)(1...
V(inside)=32832 cub. ft.
V(total)=V(outside)-V(inside)...
V(total)=5568 cub. ft
convert to cub. yard=206.22 cub yd.
Jan 10, 2011 | Computers & Internet
S10L7 displacement
Recommended Sealed Enclosures – Moderate Efficiency
  • 0.66 cu ft is the displacement of the sub
  • S10L7 .66 cu.ft. Power Handling = 600W 1.0 cu.ft. Power Handling =600W
  • 18.69 l 28.32 l
The following page shows examples of the minimum enclosure sizes for each of the Solo- Baric L7s. Panel dimensions assume 3/4" wood thickness. 5 Panel dimensions for minimum recommended enclosures: Model Volume (cu.ft.) Panel A Panel B Panel C S8L7 0.33 10"x10" 10"x8" 8"X8.5" S10L7 0.66 12"x12" 12"x10.5" 10.5"x10.5" S12L7 0.88 13"x13" 13"x11.5" 11.5"x11.5" S15L7 1.5 16.5"x16.5" 16.5"x11.5" 15"x11.5"
Jun 03, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I need a vide controller fr mercury pi865gm . desktp. plzzzzzzzzzzz help. where to dwnload t fr free ?
Try this link http://www.mercury-pc.com/downloads.php
Under Search by Product tab
Select Mainboard under Select by Product Category
Under Select Product Services
Go to Pentium 478 Series and select Intel Chipset
Your Mercury pi865gm item should appear under Select Sub-Category. Hope this helps.
Apr 07, 2010 | Mercury P4VM800M7 Motherboard
What is the rms and voicecoil configureation on these the older aw1200
here is all the specs for your sub
12" subwoofer with two 4-ohm voice coils
» carbon composite cone with foam surround
» heavy-duty cast-aluminum basket
» power range: 50-700 RMS watts (350 watts per voice coil)
» peak power: 1400 watts
» frequency response: 20-500 Hz
» sensitivity: 94.65 dB
» mounting depth: 5-5/8"
» sealed box volume: 0.50-1.50 cu. ft.
» ported box volume: 1.30-3.30 cu. ft.
Aug 04, 2009 | AudioBahn AW1200 Car Subwoofer
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Size of boxes
Wow you are in luck, I used to be an Audiobahn dealer. Designing sub enclosures is my fulltime job. So here you go.-
If you are looking for sound that is very smooth, and has a very low end shaking everything setting off car alarms. You will need a PORTED BOX that is 3 CUBIC FEET FOR EACH SUB WOOFER. It actually calls for 2.7cu.ft but after you add speaker displacement and bracing it should be at least 3 cu.ft. The port can be either round or square made of plastic or 3/4" wood respectively. My port suggestions are dependent on how much space you have. The shortest round port might make some noise (too much pressure!). So think about that first. Anyway the short port is 3" diameter and 15.5" long. The longer port is 4" in diameter and 28.25" long. The rectangular wood port can also be either (port measurements are inside diamensions) 3" w x 3" w x 18.5" long (short port) or 2 w x 10.5 h x 48' long. The second longer wood port is recommended most but will take up a lot of space. The fact that you have to subtract the port volume from the box makes for space issues in cars. Also the second wood port sounds better and won't make much wind noise, but takes up .75 cu.ft worth of space. So in plain english your box will have to have an internal volume of 3.75cu.ft. An example of this could be made of 3/4" thick MDF, have 1" x 1" internal bracing and measure (box dimensions are external and assumes the use of 3/4" MDF) 12" h x 18" w x 30" deep. The port is an integral part of the box fitting inside. I'm sorry I can't provide any drawings to make things easier. Now this box size is one that I ran through a computer program I use. So it is not the same as the manufactures recommendations. I will list those as well.
The second box is an example using a round short port and also uses 3/4" MDF, 1 x 1" bracing, the 3" dia x 15.5" long port, and measures 12" x 18" x 24" externally.
If space is an issue try checking out the information below. -I got it from Audiobahn-
If for some reason it doesn't show up or you need assistance let me know. Good luck and enjoy your new setup-I'm sure you'll be happily disturbing the peace soon!
-Dynami
Model # AW1006T
Ported
Air Space (Cu. Ft.) 0.65
Port Size (Inches) 2 x 6.5
Port Vel. (%) 48.31
-3dB (Hz) 31.5
Tune Freq. (Hz) 40
Sub Disp. (Cu. Ft.) 0.21
Port Disp.(Cu. Ft.) 0.01
Total Vol. (Cu. Ft.) 0.75
Ported
Air Space (Cu. Ft.) 1.4
Port Size (Inches) 3 x 6.75
Port Vel. (%) 24.19
-3dB (Hz) 30
Tune Freq. (Hz) 39
Port Disp.(Cu. Ft.) 0.024
Total Vol. (Cu. Ft.) 1.5
Ported
Air Space (Cu. Ft.) 2.4
Port Size (Inches) 4 x 6.25
Port Vel. (%) 14.39
-3dB (Hz) 29
Tune Freq. (Hz) 39
Port Disp.(Cu. Ft.) 0.04
Total Vol. (Cu. Ft.) 2.5
EBP 74 80 80
Sealed NR NR NR
Minimum (Cu. Ft.) 0.5
Maximum (Cu. Ft.) 1
SPL (dB) 80
All sealed boxes already include the displacment for the subwoofer. NR = (Not Recommended)
Mar 08, 2009 | AudioBahn AW1006T Car Subwoofer
What size enclosure (sealed)for Alpine 12"1242D(METAL Music)
  • 12" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 25-500 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 85 dB
  • top-mount depth: 7-5/8"
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
  • For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
    Hope this helps :)
    Dec 10, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    Size of older GW Microwave
    If you want to calculate the volume of an object and have the answer in cubic feet.
    Volume=Length X Width X Height
    With the dimensions you give
    Volume=12.5in X 37in X 20in
    Volume=9250 cubic inches
    To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
    L X W X H = 12"X12"X12"=1728 cu in
    You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
    your answer is 5.35 cubic feet.
    12 inches in 1 foot
    144 square inches in 1 square foot
    to convert you put the unit you want to keep on top of the dividend.
    to conver to to feet ( randomly selecting 100 inches)
    Example converting 100 inches to feet
    100inches X ____1ft____ = (100/12) = 8.3 feet
    12inches
    or cubic inches to cubic feet
    4000 cubic inches to cubic feet
    4000cu in X ____1cu ft____ = ( 2.33 cu ft)
    1728 cu in
    if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
    it also works in reverse
    2.33 cu ft X ___1728 cu in____ = (4000 cu in)
    1cu ft
    Jun 03, 2008 | GE JE1540 Microwave Oven
    Fusion 10" Single-Voice-Coil 4-Ohm Marine Subwoofer Logo
    76 people viewed this question
    Top Fusion Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    hoyzee1
    Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
