Back to:
Tags:
Brother MFC-9420CN All-In-One Laser Printer
Won't print
posted by Twiglet on Jun 01, 2007
My printer wants 'troubleshooting and routine maintenance' and just won't print anything until it gets done!! I cannot find the manual - in fact never saw one to begin with! I guess it's probably easy if the manual was at hand.
Comment by Twiglet, posted on Jun 01, 2007
yes, i found the manual! and an engineer needs to come, thanks for your help.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
24 seven
Rank:Wiz Wiz
Rating: 82%, 1175 votes
have you searched brother's website for manual?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Won't print:
I don't want to Accept this solution
Can you Help with these Printers problems?
I manually refilled my cartridges and when printing there...
I've look at the user guide and nothing in there helps. I...
My MFC-9420 was recently serviced and the toners replaced....
Paper gets jammed in fusing unit. Using new paper and...
the error message says: Check Tray #1 / reinstall tray....
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
