Question about Vornado VH2 Compact Heater
Vornado VH2 stopped working. on/off not functioning
My Vornado VH2 space heater stopped working. The on/off switch stays in one position, and the thing won't turn on even after unplugged then replugged in. It was one when I left, then came home from work and found this odd problem!
  • 59 Answers
If it is a rocker type switch replace the swich
IMPORTAINT make shure switch it is replaced with is rated at 15Amps
Posted on Jan 19, 2009
I have the same problem. The heater is 3.5 years old. The warranty is 5 years. I emailed Vornado and they started the warranty replacement process. Good service so far.
Posted on Jan 10, 2013
Vornado eh1-0020 was working fine and just suddenly stopped. No lights, no hum - just totally dead. Opened it, dusted, connections look ok. Anything else I can check or is it just
These heaters have a thermostatically controlled safety switch. It works very similar to your household iron for pressing clothes. On your iron, when the unit heats up the metal in the switch expands and "clicks" open stopping the power from heating up the element any more, then when it cools down it "clicks" closed and power is applied to the heating element again. Now here is the problem... in your heater, the elements are over-heating and causing the safety switch to "click" open stopping ALL power from going to the unit. IF you sit there long enough, you will eventually hear the "click" of the switch cooling down and then you will be able to turn it back on for a short time - then it will do it all over again. =( Unfortunately, this seems to be a common problem with this series of heater. There really is no "good" repair option as the price you will pay for someone to "fix" it, would probably be better spent going towards a new heater.
Oct 27, 2011 | Vornado EH1-0020-01 Compact Heater
My Vornado VH2 heater stops heating several moments after switching on. The fan runs but no heat. The heating elements never get hot but all the wiring appears to be firmly in place. The tilt shutoff...
A big problem with these heaters ans well as others is the motor driving the fan. The bearings get stiff from dirt and do not spin fast enough activating the over temp device of the heating element. Check the motor out by placing the unit in fan mode them pull the plug or turn off looking at the fan to see how many revolutions is makes with no power applied. It should rotate like five times or more indicating freeness. If it hals to a stop immediately after power is removed the motor bearings are tight.
If your handy you take apart and oil the shafts using 3inone motor lube. Clean the motor of dust and dirt drop a few drops on the shafts near the bearings then work it in by hand rotating the blades. Do this a few times reassemble then ler ripp!!!
Feb 15, 2011 | Vornado VH2 Compact Heater
My vornado heater stopped working.
vornado tv 500 work 2 minutes and stop forever
Feb 01, 2011 | Vornado EH1-0014-01 Compact Heater
Vornado VH2 heater appears to switch on, but fan and heating element no longer come on. Any solutions?
For some reason the re-set system had clicked off. Unplugged the unit for a while, and when plugged back in it was working once again.
Dec 22, 2009 | Vornado VH2 Compact Heater
Does not turn on
This is a pretty common issue with these heaters. The switch can easily be replaced by opening the unit and swapping out the switch assembly. One switch I have found that works well and is reatively inexpensive (under $4) is the one from Radio Shack (P# 275-0020) which is a 16A 125VAC illuminated round rocker switch. Unlike the OEM one that drops in, the RS one is a panel type which you will have to screw into place. The whole procedure shouldn't take you more than 15min.
Dec 21, 2009 | Vornado VH2 Compact Heater
I need a new on/off switch
I have the same problem with a VH Vornado heater
No need to change switch.
The switch has to sets of contacts, but uses only one. This one is burnt out
Just reconnect the black cable (hot) to the opposite free switch connector.
Then interchange the white (resistance) with the brown cable (ground for switch light)
You may have to turn around the switch because the heater will turn on on the "OFF" position
Check your cables with tester, to avoid any short circuit.
Dec 15, 2009 | Vornado REH1-0001-01 VortexHeat Compact...
The fan has quit on my Vornado VH2 portable heater.
take apart the heater clean the bearings, and oil the shaft around the berings lightly with all purpass oil
Jan 19, 2009 | Vornado VH2 Compact Heater
I have a Vornado VH2 portable heater. The fan has quit working.
generaly a problem like this ocures because of gummed up bearings
1.take apart heater
2.remove fan
3.wipe of bearings
4.lightly oil bearings and shaft around bearings ## TO MUCH OIL COULD POSE A FIRE HAZARD :0
5.asemble
6.test
Varnado EH1-020 VH2 blows cold air or wont stay on
THERE IS A LIMIT SWITCH THAT REGULATES HOW LONG THE HEAT STAYS ON SOUNDS LIKE THIS LIMIT SWITCH WHENT BAD MOST ITEMS LIKE THIS HAVE A FACTORY WARRANTY THAT COVERS THIS ISSUE MY RECCOMENDATION IS TO TAKE IT BACK TO WARE YOU BOUGHT IT OR IF YOU LIKE TAKE IT APART WHILE IT IS UNPLUGGED AND LOOK FOR A LITTLE DEVICE THAT BREAKS ONE WIRE TO YOUR HEATER ELEMENT AND TRY TO MATCH IT UP AND REPLACE IT.
Dec 27, 2007 | Vornado EH1-0020-01 Compact Heater
Vornado will not stay in fixed position
put some rubber washers between the floor bracket and the fan housing and tighten the knobs in which position you want
Aug 07, 2007 | Vornado Circulating Fan
Vornado VH2 Compact Heater Logo
2,155 people viewed this question
Top Vornado Heating & Cooling Experts
Bill Long
Lyle Siemens
Lyle Siemens
Roberto Lopez
Level 1 Expert
Are you a Vornado Heating and Cooling Expert? Answer questions, earn points and help others
