Question about Hoover Refrigerators
Hoover frost free Fridge Freezer ( Hcf6200a ) Not Freezin??
Firstly the appliance belong to my Mother, I live many miles away.
Fridge freezer is only a year old. Never had a problem with it before. Green light showing to indicate its on. In the last few days the 4 Drawer freezer section has stopped freezing. There is dial to adjust temp. Goes from 1 -5. Currently on 4. (She has had a very cold spell of weather were she lives...don't know if this is significant) The fridge section is working fine.
many thanks Ian
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
woodchuck789
  • 4070 Answers
SOURCE: Fridge Icing up on N1B Candy frost free fridge freezer
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Posted on Sep 02, 2009
Testimonial: "Really useful advise, with link to more help. Thank you"
SOURCE: my fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
Posted on Feb 24, 2010
jmgldsmth
  • 2005 Answers
SOURCE: My HFA290GB Hoover Frost Free Fridge Freezer has
check and, or, replace the defrost timer
Posted on Jul 17, 2010
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
Hoover a class, fridge freezer, fridge keeps icing up and is supposed to be frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | Hoover HCA390FFK Bottom Freezer...
GSL25JFPA - Freezer not freezin
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 12, 2010 | GE Refrigerators
I have a Hoover upright fridge freezer which is not cooling in either fridge or freezer unit, the thermostat control does not click when turned up or down. the appliance is 4.5 years old. model no....
IF THIS IS FROST FREE IT DOES NOT USE THERMOSTAT BUT A CONTROL BOARD. LISTEN TO COMPRESSOR ,IF RUNNING THEN GAS IS LOW(R600a) LOOK FOR YELLOW TRIANGLE ON COMPRESSOR. IF IT RUNS TOO LONG LIKE THIS COMPRESSOR WILL RUN BUT NOT PUSH. ONLY WAY TO TELL IS TO PAY FOR AN ENGINEER TO COME,FIT A VALVE AND CHECK IT. JON THE FRIDGE DOC.
Mar 07, 2010 | Hoover HMA280K Bottom Freezer Refrigerator
HOOVER HCF6200A. After cold spell in January, the freezer section does not seem to freeze products. Frozen items stay frozen but soft scoop ice cream melts and water takes an eternity to freeze. Fridge is...
check your warranty period
if it for longer than 12 months , the warranty service is free regardless
they may want the deposit in case the problem is not warranty related and would be obliged to refund it if the fault was covered by the warranty
Jan 31, 2018 | Freezers
My frost free fridge freezer is too cold and freezing the food in the bottom drawer there is some ice around the bottom drawer
You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
Contact an appliance service company.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge/freezer : freezer appears to be working okay but fridge is frosting up despite changing the temperature dial
hi. thanks for the question .You mean the freezer is frosting up. not the fridge . check the defrost timer. and termination switch. and defrost heater . one of those three parts has failed thanks the appliance doc
Oct 01, 2008 | Hoover Refrigerators
I have a 10 year old hotpoint mistral plus frost free fridge freezer whic keeps coming up with EA as an error message in the display screen. We have turned the appliance on and off which sometimes solves...
thanks for the question yes it very well could i would pull fridge away from the wall and clean the condenser if dirty makes all the difference especially in that heat thanks the appliance doc
Sep 24, 2008 | Hotpoint Refrigerators
Refrigerators Logo
79 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
