Question about Canon imageRUNNER 5000 Copier
Error code E000004-0010 on 3 5070 at the same time
All 3 of our 5070 units went down with the same error codes at the same time Any advice? Thx
  • 318 Answers
First clear the error.
Press usermode star and release,press no2 and 8 at the time and release and press usermode star again and release,then you are in maintenance mode.
select copier,funcktion,clear,select error press ok,swiths the machine off at the main switch and on again.
That will release the errors
Posted on Jan 08, 2009
    Sniper:
  • 54 Answers
Do the following first
press additional function button once,press2&8same time once again press additional button button select<copier><function><clear><error><ok>
if m/c is not ready check heater lamps,thrmostst
Posted on Jan 21, 2009
Error code:P21 and P8
try to go to your printers and faxes it is located in the start menu.
Apr 03, 2014 | Konica Minolta Minolta Bizhub C253 Copier
The tv is a model# WS48311 serial# 106199. The prob is the set turns on (green light) after 1-2 seconds it shuts off It is a Mitsubishi
Hi Sheldon,
First of all, thank you for posting your question here at Fixya.
The symptoms you've mentioned is an indication that the unit gone to malfunction. My first advice is to unplug the unit from the outlet(AC source) for at least 15 minutes to reset the system and then check if the symptoms remain the same. If yes, lets check the LED error code to determine where the fault came from by following the steps below.
Press and hold for 5 seconds the front panel button keys "Input" and "Menu" at the same time to activate the error code mode. The LED will flashes a two digit error code.
Example : if the error code is "22", the led will flash two times pause and then flash again two times and the error code will cycle for five times.
Please let me know the result to continue our diagnosis.
mjsazon
Jan 17, 2012 | Mitsubishi WS-55513 55" Rear Projection...
My kenwood kdc-st742u went into protect mode how do i fix it?
"Protect" is an error code for short and overload. Once the power applied to the unit and shorts sensed by the processor the unit will automatically turned to protect to avoid further damaged to other parts. Most shorts is in the supply voltage (B+, Vcc) line and most common caused is the sound output IC (mounted in heat sink). This part is responsible for amplifying the audio from the pre-amplifier stage and will feed to your speakers.
If you have a knowledge in disoldering and soldering technique, I would advice you to pull-out this part and then try the unit. If the error code is gone then you must replaced this IC with a new one to back your unit in normal operation again.
Before that, turn on first the unit without the speakers loaded to determine if the error code is not trigger by faulty(shorted) speakers.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jun 28, 2011 | Car Audio & Video
I have 2008 F350 Super Duty Crew Cab. Started getting "check brake system" error msg on control panel. Brakes went clear to the floor 3 times in wet weather, but still stopped me. Dealer claims...
check brake system alerts you to check them --low fluid ,low pedal ,the brake trouble light would be for blown line no pedal type and that would code --as to price for whats being done is normal
Aug 10, 2017 | 2008 Ford F-350 Super Duty
Error 6A00 Pixma i830
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error c3451
First ignore the revious solution, it is not even close. The error code c3451 refers to a copier warm up error, the machine had not reached the correct temp within a specific time. I bet it happened when you first swiched on one morning. Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
hope this helps
Jan 09, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Ford radio rds 5000 code
same problem need a code for my ford rds 5000 serial is m238547
thx everyone
Aug 04, 2008 | Car Audio & Video
Error code RC3
I absolutely can't believe this worked for me, I'm so excited!! My error was RC3; my remote had an OK button (not Enter) for a Panasonic DVD/VHS recorder. I held down OK and the number 3 and the remote started working!! Thank you so much, I was getting very frustrated!
Sep 12, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Canon imageRUNNER 5000 Copier Logo
2,722 people viewed this question
old marine
old marine
