Question about Dryers
Sears Kenmore 70 Series
Push start button dryer will not run but button hummms the kick totally off after a fes seconds.
    Sergeant:
    Champion:
  • 262 Answers
SOUNDS LIKE THE MOTOR HAS SOMETHING STOPPING IT FROM TURNING LIKE DOVE THE LINT FILTER HOLE OR EVEN THE MOTOR IS BAD CHECK AND SEE IF THE MOTOR IS STUCK AND LET ME KNOW WHAT YOU FIND
BILL
Posted on Jan 08, 2009
Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 08, 2010 | Kenmore 63952 Electric Dryer
Have a Kenmore Haevy Duty 70 Series Soft Heat model #96576200, I set the time push the on button dryer comes on to start drying but shuts off within 30 seconds. Any suggestions would be appreciated
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
a
Sep 27, 2010 | Kenmore 700 6972 Dryer
Have a Kenmore 70 Series, Heavy Duty Dryer. Push the on button to start, nothing happens.
heatman101
Sep 19, 2010 | Kenmore 700 6972 Dryer
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series dryer has power just wont start when push the button is it the start switch?
could be the start switch or it could be the safety switch in the bottem of the dryer that turn the dryer off incase the belt brakes.
Oct 02, 2009 | Kenmore 63942 Dryer
Sears Gas Dryer won't run
sounds like you have a bad fuse. does yours have a kick panel? sounds like you have a bad timer and fuse.
Jun 01, 2009 | Kenmore 74602 Gas Dryer
Kenmore 90 Series Dryer start button humms, but that's it.
MOTOR HAS GONE BAD,IF YOU WANT TO TACKLE IT THE MODEL NUMBER IS INSIDE THE DRYER DOOR,YOU MIGHT FIND A GOOD DEAL ON EBAY OR GO TO SEARS.COM UNDER APPLIANCES,LET ME KNOW AND I WILL HELP YOU WITH IT-MIKE
Mar 06, 2009 | Kenmore Dryers
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Kenmore Dryer 70 series
Hi, the problem with the dryer not stopping is most likely the switch that controls when it starts. This switch is located behind the button you would push in to start the dryer, and if you can take off the rear panel and get to it, you can most likely adjust the internal contacts so that they don't continuously make contact. Or you could just replace the switch, which might be easier!
Jul 21, 2008 | Kenmore 64742 Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
