My vaio turns on but wont boot up model is a vgnnr17g
    Guru:
  • 571 Answers
Try booting it up to safe mode. Just keep tapping F8 to go to the options where you can select safe mode. After that, use your keyboard to select safe mode. If it goes to safe mode, restore it to a date when your computer was still working fine.
To do the system restore, do the following:
Start or pearl button (click) > Accessories > system tools > system restore .
If you can't boot via F8, then use the Operating System's Disc that came with your computer when you bought it. Turn on your computer with the disc inside it. Follow the onscreen instructions and do a repair in the operating system.
I hope this helps.
Posted on Nov 21, 2012
SOURCE:
Boot problems
With either the system recovery disc or a windows install disc you will most likely need to re-install the operating system. If you have neither you will need to order a set for your model from Sony's site.
Feb 02, 2013 | Sony VAIO VGC-JS210J/B 20.1 in. PC Desktop
How to Boot Sony Vaio VGN-S460 Laptop without CD/DVD ROM and With bootable USB
If the BIOS does not have the USB as one of the boot options then you cannot boot up with an USB memory stick.
In this case you need to replace the CD/DVD drive with a new one.
Jan 17, 2013 | Sony VAIO CS VGN-CS220J/T Notebook
Sony vaio a417m wont boot
If you only want to enter BIOS then you can try the below keys .
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Aug 06, 2012 | Sony VAIO Notebook
Sony vaio vgn-fj270 bios wont boot, just display [Be-$]Be-$
try to turn off the laptop. Remove cables and battery then press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop. Turn on the laptop. Check if the BIOS screen appears. If it is still wont boot to windows, try to restart the pc and repeatedly press F8 to Boot to safe mode. If unsuccessful, this might be a problem with the memory of your laptop. If you cannot tear down the laptop, consult a technician to tear it down and reseat the memory .. or better call your manufacturer to repair it...
Jan 05, 2011 | Sony VAIO VGN-FJ270/B Notebook
Vaio wont start up shuts off
check two things, video (reinstall drivers) and the other may be a heat event, look in the BIOS set up in the event log.
blow dust out with compress gas especially around the heat port and exhaust fans.
May 15, 2009 | Sony VAIO VGN-FS840/W Notebook
My sony vaio is not booting up and i cant recover it
Go into the BIOS of laptp and change the boot order like
hard disk
DVD
usb
etc.......
then save changes.exit
Apr 03, 2009 | Sony VAIO VGN-FJ170/B Notebook
Sony Vaio desktop will not load windows
what your describing is a hard disk failure the computer cant or wont read the hard disk to boot the machine, so it shuts down. Sounds like the hard disk died from a bad virus. and the computer wont run. Best I can do for you is either format the Hard disk and reinstall the operating system or buy a new hard disk. Cheers
Apr 01, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Vaio Sony wont go to the users acount
Hold button down for 5 seconds to switch off. The switch on and press F8 and choose safe mode boot. If it boots try a repair option or system restore to a previous working state
Nov 16, 2008 | Sony VAIO PCV-W600G PC Desktop
Sony Vaio PCV-RS710G wont start up
one of the files in the system32 directory in the windows folder is corrupt, the files in the system32 folder contains vital files for the boot procedure, try to start the machine in "safe mode" by pressing F8 after the sony boot screen, if it allows you into the operating system you will need to choose "system Restore" take the time back to at least a week before your problems started DO NOT CREATE A RESTORE POINT
Nov 14, 2008 | Sony VAIO PCV-W600G PC Desktop
Wont boot up
Could be bad memory, try and get into the bios and turn off the quick boot feature, this will run more complete tests. Also try booting using KNoppix or Ubuntu, make sure u set to boot from a CD in the BIOS. If Ubuntu or knoppix boot's you'll know it's the Hard disk, if they don't, it may be the RAM,
May 08, 2008 | Sony VAIO PCV-W510G PC Desktop
Computers & Internet Logo
37 people viewed this question
Ekse
Alun Cox
