Question about Dryers
Dryer will not heat and timer doesn't budge when running
My Roper model REX6634PQ0 will not heat and the timer does not move no matter how long it runs. What do you suggest I check and is this something I can fix myself?
  • 1 more comment
  • apugh1968 Jan 08, 2009
    Electric dryer, but I don't think it's the timer. It will run on the perm press and timer works. Heavy cycle is where the dial doesn't move. Still open to suggestions.
  • apugh1968 Jan 09, 2009
    I took out the heating element yesterday and it is shot! Problem solved! Thanks for all your help!
  • PierreCo9 Feb 08, 2009
    I have the same problem with my Roper dryer, same model. It is also electric. It worked fine last night and then this morning I noticed it was running but without heat. Was the heating element easy to take out and replace? Where did you get the replacement part?
  • 333 Answers
First of all if this is a gas dryer you should have a tecnician fix so you have no gas problems. If not it sound like you definitekly need a new timer, that is why it does not heat up. All of your cintrols run through the time. It lets the machine know when to go on or off and get hotter or cooler depending on what type of cycle you chose. I hope this helps.
Posted on Jan 08, 2009
  • Frank Russo Jan 08, 2009
    the little gear inside the timer may be worn in the heavy duty part of the timer. When you do perm press you are using a different part of the gear system
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Roper dryer model REX6634PQ0 doesn't heat... suspect heating coils bad, perhaps also fex-vent hose may be clogged... otherwise dryer works, including timer.. done so far.. cleaned vent hose...
Start by unplugging the machine and take it outside if possible.
get the screws out and remove the rear cover
Go ahead and get the front off next so you can remove the blower housing
Take the filter out and a couple screws then grab the back of the control with
your left hand and use a putty knife to release the top on each side
That smaller fuse at the top blows with a blocked vent
Service manual and videos are HERE
Aug 17, 2011 | Roper REX4634KQ Electric Dryer
Roper gas dryer does not heat, timer does not move, runs continuously, can the timer malfunction cause dryer not to heat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Oct 22, 2010 | Roper Dryers
I have a Roper Dryer it will not heat and timer will not turn off. THe handle turns it on but not off
How old is this machine and are the clothes dry and still running.? Is there a moisture sensor on this model ? Does the timer indicator move around the dial, if not timer is bad.
Jun 08, 2010 | Roper Dryers
My roper dryer REX6634pq0 does not heat!!
there is a thermal overload switch that activates the heating element. This switch will be located in the area of the element itself. It is designed to shut off the element in the event the element itself reaches a temp beyond it's designed temp. It is a safety device. If the switch is out it will not allow the heating element to activate. This switch looks like a silver button and has several wires going to it is about the size of a dime. Replace this switch and you should be good to go
Mar 17, 2010 | Dryers
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Roper Gas Dryer not heating.
Is the fuse on the picture is the one you bypassed:
The thermal fuse
- The wiring diagram which may help you.Here is information about prices n more elements that you may need. "Did I answer your question ?
Did it solve your problem?"
Jan 19, 2009 | Roper RGX4634KQ Gas Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
226 people viewed this question
Top Dryers Experts
