Question about Jenn-Air Dishwashers
Possibly not enough water pressure
I first noticed that the powdered soap in the dispenser would not empty completely and now it just doesn't sound like it used too.
This dishwasher is 12 years old. Do I try to fix it or start shopping for a new one?
  • 126 Answers
It is possible that the valve is not letting enough water through or the spray arms are not distributing it as neccessary for whatever reason it may even be that the motor is weakening with age. If you do the labor yourself it might be worth replacing a part but it is kind of hit miss on what to replace. Appliances average 7-10 years these days. In all honesty if it were my choice to make I'd put the money toward a new dishwasher. Good Luck.
Posted on Jan 08, 2009
Why doesn't our Whirlpool dishwasher clean anymore?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 17, 2011 | Whirlpool Dishwashers
My dishwasher leaves sand like residue in my glass cups. I have tried running it empty and with vinegar, it still does it, how do I stop this from happening?
Hi
Hope this helps...
Daniel
Apr 02, 2011 | GE Dishwashers
Dishes do not clean, although the water is hot and the soap dispenses. Dishes and glasses have a cloudy residue at times, and dishes sometimes have small food particles baked onto the surfaces.
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 13, 2011 | Bosch Dishwashers
Dishes are not coming clean. The detergent basket is not emptying out, after cycle has run, the detgergent is still partically in the dispencer
Hi
Jan 24, 2011 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishes not geting cleaned. Soap is left in the door dispenser only partially used.
Hi
Daniel
Dec 13, 2010 | Maytag Dishwashers
My dishwasher is not cleaning my dishes. at the end of the cycle there is still liquid in the dispenser.
Hi
Daniel
Dec 13, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Detergent is left in the dispenser cup. Dishes are not clean after going through a complete cycle.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Please post back for any further assistance.
Daniel
Aug 02, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water and soap remains in the soap tray
You need to check for blockage in dispenser, remove completely and thoroughly clean every part of it.
Other possibility is not enough water pressure to take all powder down, check water pressure, filters in hoses if fitted..
Check hose from dispenser to drum for restriction.
Plz rate my solution.
Thanks.
Dec 16, 2008 | LG WM-1485FHD Front Load Washer
Soap Dispenser Problem with Kenmore Elite Dishwasher
its possible to have a faulty dispenser, but i would look for other reasons first. Im a big powder user and proponent. powder just breaks down better in hot water.Have found that by using the tabs(whoch im sure the gel packs could give same issue) that they dont really fitting the dispenser as well they're a little tight to close the door and the spring action of the dispenser is sometimes not enough with te extra pressure from the tablets.also ck to make sure youre loading it correctly and nothing is blocking the water form spraying into the cup fully emptying it
Mar 22, 2008 | Dishwashers
Dishwashers Logo
73 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
