Is this a static or a buzzing sound. If a buzzing sound, make sure your AV cables are plugged in correctly.Is this a static or a buzzing sound. If a buzzing sound, make sure your AV cables are plugged in correctly.
You can't post conmments that contain an email address.
Most likely the VCR needs a head cleaning. This is common when playing older or rented tapes as the oxide recording surface can flake off and clog the video heads. You can try a head cleaning cassette. Make sure to get a wet-type cassette which you moisten with the included cleaning fluid.
Unfortunately this is not always successful for severely clogged heads. It may be necessary to remove the cover and clean the heads with a chamois cleaning swab moistened with head cleaner. Hold the swab flat against the round drum that holds the heads and move the drum back and forth while holding the swab steady. Repeat this for each of the heads. The heads are fragile and can be damaged by incorrect cleaning, so you might want to see what a shop in your area charges. (The shop I worked in used to charge $20, but that was several years ago.)
There's also the chance there's been head failure or some other problem has developed, but dirty heads are very common.
More likely a damaged tape got inserted, if the video heads get blocked or even partly blocked every tape after will do this, heads can be cleaned manually (careful if not sure how to do it) or a cleaning tape MAY clear this up or not.
It sounds like you have a dirty video head, you can try a wet or dry cleaning tape, I recommend a dry tape because it is easier on the head. The second option is run a brand new T120 tape and set the speed at sp (2hrs) let it run the full time.
EC means euro connector, I.E. Scart socket. For some reason there is no video signal coming out of the scart cable/out of the VCR or being displayed on the TV. Try plugging the scart plug into a different scart socket and see if that helps.
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
When not watching a tape, be sure power is off ( VCR ).....
How is the picture...? When you watch tapes, do you put the
TV on channel 3 or select video..? Also, what is signal source ?
Cable ? Box ?.....................T.
Your problem is somewhere between the tuner and video detector circuit.
The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess!
After the audio passes through all this, it is detected and sent to the audio processor.
If any frequency has drifted away from it's value then you loose the sound.
SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem.
Stargazer
please check Video head tip, if it is OK. Clean Video head with Head cleaning cassette. If Head tip is damaged head to be replace.
thanking you & best of luck.
