Question about Cisco ONS 15454 3.4.0 (15454-R3.4.0SW/CD) for PC
CISCO ONS 15454
If I'm discovering that nodes are being effected by an UPEQUIPPED PATH, how can I navigation on the CTC to find the single circuit that is causing the problem.
  • 56 Answers
Could u explain more??? what is the typr on the NET. tell us more
Posted on Jul 31, 2007
What's the difference between STM-16 and STM-16C?
STM - 16 - c grade is unicom, commonly used in data transmission business.Also didn't see you said STM-16 TUG structure is what Want to ask this problem?Are you trying to say vc12 signal multiplexing into STM -n mapping path?The online a lot of articles on the principle of SDH has ah.If you ask is the 3-7-3 structure timeslot number or line number, the general equipment is adjustable, and this only affects the business opened when docking the serial number, business can be.
Oct 22, 2015 | Cisco ONS 15454 OC-48/STM-16 ELR 100GHz...
Tip
Network failure types
<span> <p>A network which contains many network components of both hardware and software can incur failures due to one (or even multiple) of its contained components incurs a failure. Ranging from the largest to the smallest and from hardware to software, network failures can be divided into the following categories:<br /> <li>Control plane failure:</b>this type of failure is mainly related to software, i.e., network control plane software. For example, in a GMPLS-based network which is made up of a control plane and data plane, the control plane failure would lose the control of the data plane, which means that we cannot establish new service connections, or terminate or modify an existing service connections within the data plane, even though the existing connections can still perform normally to carry user's data. In other type of networks such as IP networks, the control plane failure can be even more serious. For example, the pollution of IP lookup tables at some routers would cause all the IP traffic on these nodes difficult to be forwarded. Similar stories occur for viruses attacking IP routers. They disable the IP networks through disabling IP network control plane.</li> <li>Subnetwork failure: </b>this is a type failure occurred with a regional subnetwork that commonly shares a risk, e.g., a region that has high occurring frequency of earthquake. In addition, some large disasters such as flooding, tsunami, etc. can also disable a regional subnetwork.</li> <li>Node failure: </b>this is a type of failure occurred with a single network node. The reasons for this kind of failure include accidents or disasters at a network operational center, such as power shutdown due to fire, flooding, etc.</li> <li>Network card failure: </b>network card failure is a type of failure under the umbrella of the node failure type. Rather than the shutdown of the whole switch node, sometimes a failure can occur only with a network interface card. For example, the failures or faults such as a laser outage, fault of a circuit board, or software bugs, etc. can also contribute to a network card failure.</li> <li>Link failure: </b>link failure in general is the most common network failure that occurs due to fiber cut.</li> <li><a href="http://www.network-protection.net/shared-risk-link-group-srlg/">SRLG</a> failure: </b>SRLG failure is a generic concept to define all types of network failures whenever a common SRLG incurs a failure. Here a SRLG can be a fiber link, node, subnetwork, or control plane, etc.</li> <p>Single failure and multiple failures: in general network failure implies a single network failure because network failure normally seldom occurs. However, under some situations, there can be more than failure occurring with a network. This kind of situation is called multiple failure, example, dual failures and triple failures. For a network, planning for full recovery of multiple failures generally requires much high protection capacity than that of purely for a single failure.<br /></span>
on Jan 04, 2011 | Cell Phones
What collaboration capabilities are available on the new Cisco 2900 and 3900 Series routers?
According to my experience and knoledge: the Cisco 2900 and 3900 series platforms have collaboration feature parity with the Cisco 2800 and 3800 Series platforms, so all of the following collaboration capabilities and solutions are present:
• Cisco Unified Survivable Remote Site Telephony (SRST)
• Cisco Unified Border Element
• Time-division multiplexing public-switched-telephone-network (TDM PSTN) and private-branch-exchange (PBX) gateways
• VoiceXML contact-center gateways
• Cisco Unified Communications Manager (UCM) media resources (allowing conferencing, transcoding, and Media Termination Point [MTP])
• Resource Reservation Protocol (RSVP) Agent
• Cisco Unified Communications Manager Express (CME)
• Cisco Unified SIP Proxy
• Gatekeeper
Cisco 3900 Series Routers
Jun 25, 2014 | Computers & Internet
Check Toner/Drum CRG I Replaced Both Stil I have Same Problem.Please can u tell me How can i fix This problem?
Sounds like you need to reset your counters.
Check these areas on your printer to see if you can locate them.
To select events that will raise alarms:
1. In the navigation pane, expand the Canon Devices node and the Configuration
node, and click Alarm Management.
2. Select the check box for each type of information you want alarms generated for.
3. Click Apply.
Specifying Rates and Timeouts
To set rate and timeout values:
node, and click Rates and Timeouts.
2. In the Discovery Refresh Rate list, click how often the client should refresh the
navigation pane's list of discovered devices.
3. In the Alarm Poll Rate list, click how often the client should poll for alarms.
Apr 01, 2011 | Canon imageRUNNER 1310 Printer
What do you mean by short circuit?
if the positive wire or negative was touch anthing, that means a short circuit
Mar 20, 2011 | 2002 Isuzu Axiom
I am configuring a engenius eoc-3610 with wds on a wrv210 cisco wireless router but the internet once setup is very slow.
Every node added to a WDS network cuts the network transmission speed in half. This is just a characteristic of any WDS connection, as WDS is a repeater protocol (it has to retransmit everything it receives).
It's not clear from your description whether you are trying to add the EOC and the Cisco to the same WDS network. If that is the case, it's a wonder you got it to work at all, since WDS implementations are model-specific, and usually require every node to be exactly the same model router.
Sep 24, 2010 | EnGenius 802.11b/g Wireless Access Point
SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Jul 03, 2009 | Konica Minolta bizhub C250 All-In-One...
How do i remove Nmti if it affects port or frame relay resource
Hi Christina,
The problem come up or happened because the link (E1/T1...) problem or 3600 series going down e.g power down etc. The effect of it sometimes influenced the circuits mainly the circuits made by nmti software via hyperterminal, 4601A even 5620 NM (integrated NMTI).
To solve the problem first you have to clear or de-configure the configuration/cross-connect via nmti and than you connect again the circuits. Please using Alcatel 5620 NM GUI to make cross-connection or circuits (Circuits Switch Data).
Regards,
jhadori
Mar 22, 2009 | Alcatel Newbridge MainStreet 3600...
Network browsing is very slow in our workgroup
try giving all the nodes static IPs Add. OR check for Worms on the nodes coz they navigate through network , choking the switch
Dec 14, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
57 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
