Question about Amana ABB1927DE Bottom Freezer Refrigerator
Temperature setting what is the lowest number?
  • sadie_salad Jan 12, 2009
    my food in the bottom drawers and shelves are freezing---so this information about the temp setting is also helpful---I don't have an "owner's manual"--it is a new in 2000 refrig but installed by contractor who didn't leave the manual---I just cleaned the coils underneath in hopes that will help---will see--the previous suggestion to clean out the water drain baffles me as I can see a hole in the back wall mid-way down but how to know if that seems a weird place for a drain
The higher the number, the colder the fridge/freezer. You should just adjust 1 number per 24 hours per the manual instructions.
Posted on Jan 10, 2009
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
How does thetemperature dial on upright phillips freezer work
Usually 6 would be the higher (colder) setting.
Aug 14, 2014 | Refrigerators
Coldest setting 1 or 7
On my fridge it also says ? C, meaning the 1 to 7 are degrees Celsius. Making the one the lowest and the 7 the highest temperature.
Jul 28, 2014 | Whirlpool Refrigerators
Which will provide the lowest heat? low 10 hours or warm setting. Thanks
The WARM setting is the lowest heat. Here's a quote from the user manual:
"WARM is ONLY for keeping already cooked food at the perfect serving temperature. DO NOT cook on the WARM setting."
This is because at the WARM setting, the temperature doesn't get hot enough to kill food-borne bacteria.
Jan 18, 2011 | Rival 38601 Smart Pot 6-Quart
On the inside refrigerator temperature knob is 1 the coolest or warmest temperature?
most often the lowest number is the warmest setting, and the highest number is the coldest setting.
Dec 10, 2010 | Danby Designer DAR1102W Refrigerator
Milk, lettuce freezes after temperature is reduced
turn both control to the same number the lowest number and then wait 24 hrs if you want it needs to be cooler move both controls 1 number then wait 24 hrs and see if you are happy
Apr 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Heat settings on enheat slow cookers
Generally, the lowest number is the lowest temperature setting and the highest number is the hottest temperature setting
Jan 02, 2010 | CorningWare SC60 Slow Cooker
What is the normal and the lowest temperature that the Haier HNCM035E, 3.5 CU FT capacity C hest Freezer will susstain?
WATH IS THE NORMAL AND LOWEST TEMPERATURE THA THE SMALL MAGIC CHEF FREEZER MODEL CUF3DS
Sep 10, 2009 | Haier Freezers
Feezer keeps defrosting itself
Try adjusting the thermostat (freezer setting). Crank it from lowest to highest to lowest a few times, and then leave it set on the lowest setting. That may get something unstuck. You could try putting a little light (low viscosity) silicone oil on the working parts of the thermostat. Silicone oil doesn't get thick at low temperatures.
Jul 31, 2008 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
107 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
