Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Snowblower auger quit
I inheirated a pretty old wedgefield snowblower. I got it running no problem and got about 3/4 of my driveway finished when the auger stopped turning. WHen i move auger lever on to off it doesnt even flinch. none of the shafts are turning at all??any ideas...thanks
  • Anonymous Feb 13, 2009
    I have a old toro 521 I replaced the auger belt but they still don't move
4 Suggested Answers
ToolBoxHero
  • 171 Answers
SOURCE: My Craftsman 5.0 horsepower 5
If the blower (impeller) turns and the auger doesn't there is a 90% chance you broke the shear bolts that protect the auger gear box.
Look at your auger and you will find the bolts shown at the arrows in this picture are missing. Some snowthrowers will have two bolts and others like the new Craftsman will have four.
You can get new ones at your local mower repair shop, your local Sears mall store, or online at sears.com.
Use shear pins or shear bolts not regular bolts. The shear bolts are designed to break off so you don't tear out the front gear box.
Feel free to ask any other questions. Don't forget to rate this answer!
Posted on Jan 13, 2011
  • 3074 Answers
SOURCE: I have a 8HP 2 Stage Wedgefield Snowblower. I
you could call Sears as they sold/carry this item, but the length and width would allow you to check at a car parts store. Good Luck Tim
Posted on Oct 19, 2010
vincob
  • 718 Answers
SOURCE: my 9hp sears snowblower doesnt through snow
Usually on the bottom of those there is a scraper plate on the bottom behind the auger this is made to wear out check to see if needs replacing.
Posted on Mar 10, 2011
I have a MTD snowblower yard machine.how to adjust
There should be metal shoes on the side of the snowblower. They have adjustment bolts that allow the auger housing to move up and down. loosen them and adjust to how close you want it to the ground. It also depends on the model. This process only applies to large self propelled models which are a two stage snowthrower. if its a small single stage there is usually no adjustment.
Oct 19, 2014 | Garden
How to remove the belt from craftsman snowblower model C459 52560 MFG code 1/055/3-0079
Unfortunately like many other snowblowers you first need to seperate the auger/blower assembly from the drive/engine assmbly. Pretty straight forward after that. Make sure you put belts on the right side of the metal tab that cleans the back side of the belts when running or you'll they'll cut in two the first time you engage the auger
Dec 17, 2010 | Kitchen Ranges
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
Borrowed a neighbor's snowblower last night and cleared a driveway. Stored blower in unheated garage. Went to use blower today and got it started but the auger would not move. Very little wiggle in auger...
using the snow blower warmed it up ,it developed moisture in it then you put it away then it froze put a electric heater next to it but keep it away from the water[ the heater i mean].
Dec 21, 2009 | Toro Lawn Mower With Toro Power Tools
Oil leak and stall
I have not solved the problem yet, however, at this point I am thinking it may just be a crankcase vent problem. Builds to much pressure and stalls and that is also the cause of the leak??? I used the blower again today and when I took out the dip stick there seemed to be a pressure.
I had listed my problem as a lawn mower cause the snowblower wasn't in your list of options to pick from??
Mar 25, 2009 | Garden
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Dec 23, 2008 | Craftsman Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
248 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
