Question about Zebra Z4M Printer
No print with ribbon
I have been printing labels that did not need a ribbion. I have recently changed to a plastic label that requires a ribbon. But even yhough the printer goes through the motions, it does not print anything. I have a Zebra Z4N Plus.
  • 3 Answers
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Posted on Jan 27, 2009
I had to change the ribbon in our B-472-QQ and now the print quality is very bad. Can hardly read the label. Tried changing the ribbon again, same results. Any help would be appreciated.
First of all.
B472 uses a near edge technology for printing.
You must use Ribbons for near edge head.
- You must use a WAx/resin for paper labels and Resin For Polyester or plastic labels.
You may also have your print head mis-alligned or you are not heating enough
Jul 12, 2011 | Toshiba TEC B-472 Thermal Label Printer
I am a Reseller and one of my client is having Citizen CLP-7202e. due to the faulty print head we have tried to change the print head and after changing a new print head, printer is not printing...
I have used this type of printer before. Long ago when it was called the C-ITOH. However, never had to change the print head before. I would imagine that if you did - all the adjustments would need changing. Bad Gap would skip labels and bad pressure would make them too light or too dark. If there are any vertical lines (even faint) the print head is damaged. Also, these things are very specific as to media vs ink roller. You cannot use a paper ink roller with mylar labels. Vise versa works but those rolls are more expensive. I am sure you have tested this already but you point pretty exclusively to the "new" print head with your testing. Sounds like you have answered your own question. I would do some continuity tests on the head to see if it carries any current at all. Good Luck!
Jun 14, 2011 | Citizen CLP-7202e Thermal Printer
HI, our Zebra 4m+ is currently set to a Darkness of 30 as that seems to eb th eonly way it will print enough detail on the label. We have tried adjusting the pressure settings to no avail. Now we are...
Full resin ribbons tend to require higher darkness settins on all thermal printers.
It could be a mismatch between label and ribbon. This would need to be looked by your supplier.
May 25, 2011 | Zebra 105SL Thermal Label Printer
Printer is paused alert ribbon out after scrolling out rolls of ribbon, any attempt to re-align ribbon failed so far. Which printing mode should I be? print jobs make attempt to print but goes back to...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
May 18, 2011 | Zebra S4M Thermal Label Printer
My Z4M Plus printer is not printing the label all the settings are fine no error. The ribbion shows the image but it doesnot print on the Label.
Two possiblities: 1. the darkness is not high enough for the ribbon/label combination. 2. the ribbon is on backwards. if the ribbon is on backwards, you will still see an impression on the ribbon but not on the label. This means all the ink transferred to the printhead which should then be cleaned.
The ink side of the ribbon needs to face down to the label to print so the easiest way to make sure which side has the ink is to use a label or piece of tape and touch it to the ribbon. If no ink comes up in the adhesive then that is the wrong side.
Hope that helps !
Apr 01, 2010 | Zebra Z4Mplus Label Printer
Ink smearing
This is a compatible ribbon/label combination as Zebra says. The only thing you can try is to turn up the darkness setting. The 5586 ribbon you are using requires a fairly high darkness setting ~ maybe around 25. If this still doesn't work then the best solution would be to use a Zebra card printer that prints right on the plastic card. These are made for exactly what you are trying to do. If you don't want to buy the printer then we can print them for you when you need them. I can give you my email if you want us to help.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Every label printed starts further down on label zebra 105se
It sounds like the problem is with the media sensor. Make sure you haven't loaded the ribbon through the same slot that the paper enters on the media guide. There is a reflective metal plate above the media that reflects the sensor from below the media.
May 26, 2009 | Zebra 105Se Thermal Printer
My lp 2844 will not print
Firstly is your label Thermal Direct?(DT)
To test quickly score your fingernail across the surface of the label, if it leaves a black mark then it is DT
If there is no mark then it is probablly Thermal Transfer(TT) and requires a ribbon, which you cannot use on the LP 2844, only on the TLP2844.
If you have DT labels then go into the printer driver via Printers & Faxes and the Printing preferences and change the darkness to level 7.
Try printing again.
If it works then cahnge the darkness again until you get a satisfactory print darkensss.
If it still does not print then change the darkness to maximum, does it print?
If not then I think you have a duff printer, return it to the company that supplied it for repair.
Any problems contact Lancer labels
Apr 05, 2009 | Zebra LP 2844-Z Thermal Label Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
good luck
Dec 12, 2007 | Zebra Z Series Z6M Thermal Label Printer
Zebra Z4M Printer Logo
199 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
