Question about Canon PIXMA MP210 Photo All-In-One Printer
How to replace the ink cartridges of canon mp210
Please tell me from where i can replace the ink
    Problem Solver:
  • 13 Answers
You can replace them from zellers,staples,kmart,sears or any ink store.
the best place is staples that is if you live in Canada
Posted on Sep 19, 2009
SOURCE: reseting mp210
i've refilled mp210 both cartridges.do you know how to reset the printer?cause it's show error 6,please help
Posted on Apr 03, 2008
SOURCE: Refilled cartridge not recognised by printer (canon PIXMA MP210)
get a new printer???
Posted on Jun 28, 2008
  • 15 Answers
SOURCE: Canon PIXMA MP210
Hi. This might be stating the obvious, but try cleaning the contacts in the printer and on the cartridge with isopropal alcohol. I have a Canon Pixma MP520 which I have had for most of this year now, and it works fine. I am not sure if I will be buying another Canon printer after the problems I have just read on FixYa though! Another thing you might try is carefully bending the contacts on the printer that touch the copper strips on the cartridge to ensure they touch properly. I have not looked too closely at mine, but I presume there must be copper contacts of some sort that are spring loaded, which press up against the contacts on the cartridge when it is installed. Hope that helps.
Posted on Nov 06, 2008
  • 183 Answers
SOURCE: Canon pixma mp210 printer -
Dear merryan,
This printer uses FINE cartridge which has memory chip inside that store ink level data. Once the cartridge is EMPTY we cannot restore this data to be FULL even though we physically refill ink until FULL. So the printer keep displays NO INK warning.
Similar with using compatible cartridge, NO INK warning still remain because ink level data has been recorded as empty. Why?. Here is the explanation. As far as I know no third party compatible cartridge produced this printer since canon protect it with the chip. Compatible cartridge that sold in the market is refurbish cartridge which repacked with another brand.
To fix this problem we need to deactivate ink level detection function by holding down STOP/RESET button for about 9 seconds or more for each cartridge. The consequence of this is ink level become UNKNOWN.
Hope this will be helpful to you
Regards,
Xanda
Posted on Nov 08, 2008
  • 47 Answers
SOURCE: Installed new cartridge in canon pixma mp210 & now can't print
The printer needed to be reset.
Unhook the printer then take out the new cartridges.
try to very gently clean the contacts also make sure the contact on the new cartridges is clean.
Let it dry for a few minutes assembly.
Plug it. My printer is reset by pressing the start button and hold it down until it beeps 6 times.
You can check your manual how to reset yours.
I hope it work for you.
Posted on Mar 17, 2009
Could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
This must be performed following an ink loader replacement.
2. Test the appropriate Ink Melt Heater.
Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
No)Replace the Ink Loader
Aug 03, 2011 | Xerox Phaser 8560MFP Laser Printer
My cannon mp210 is flashing E 1 6 what does that mean and how can i resolve it
E16 means that the Ink Level is unknown, if you refilled it somewhere it would cause this error to come up. The only way to make this go away is to disable the Ink Level Detection by holding Stop/Reset for button for about 9 seconds. It should now work properly but it will be unable to tell you the remaining ink level. The only way to get it to tell you this information would be to replace the ink cartridges.
Mar 28, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
We had just changed both ink cartridges but the printer still thinks that the ink is low. Is there a way to reset it?
Hi dav0369
Once you have replaced the old ink cartridges with the new you can run the printer maintenance program this will reset ink warning levels or mayb opening the lid again where the ink is replaced and closing it can sometimes tell the printer you have replaced the ink cartridges hope this info helps cheers nikki
Please rate my answer.Thanks for using FixYa.
Jan 15, 2011 | Dell Office Equipment & Supplies
I buy the wrong refill ink canon mp258 3
Throw away the refilled cartridges. Using original cartridges is the wise solution
May 23, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
How to refil Cannon LBP2900 cartridge
you do not have to take the whole printer to the shop to fill the ink cartrage if you have the manuel to the printer it should tell you how to remove the ink cartrage and replace it with a new one and also they may have a refill kit at one of your local computer stores or where they sell ink and they should be able to tell you how to get the ink cartrage out to replace it
Sep 02, 2009 | Canon LASER SHOT LBP-2900 Printer
Canon MP210 Third Party Ink Canon Does Not Work!
When the error message comes up, try pressing the "stop/reset" button and holding it down for at least 5 seconds. This works when I get an error message with compatible cartridges (only my error message says the ink is empty - and I know it isn't)
Jul 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
816 people viewed this question
old marine
old marine
