Question about Hitachi 50VS69 50" Projection HDTV
Hitachi light motor for 60v500a
I was told by a sears repairman that my hitachi light motor is bad and i need a new one. he said it will cost 1800.00 to fix it. where can i find one myself.
  • 2,326 Answers
Click here to find the part you need for your TV. I would suggest to contact them before buying it and ask them if they could provide you with info on how to DIY.
Good Luck.
Posted on Jan 08, 2009
Light is dim for hitachi model 60v500a
you need a new lamp, USD130 for a new one
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jun 24, 2012 | Hitachi Lamp for Hitachi 60V500A -...
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
Lamp light on after i replaced the blown lamp Hitachi 60v500a
Was the tv working before you replaced the lamp? if it was then make shure you have reinstalled the new lamp and the door exactly as removed, there is a disconect switch on the door that has to close when the door is reinstalled,or sometimes the ballast may go bad at the same time.Hope tha t will help you fix it.
Mar 19, 2010 | Televison & Video
Hitachi model 60v500a.the middle of the screen is a little yello
If you Google "60v500a light engine" you will learn a few things about this set which was first sold in 2003.
There are some class action lawsuits out there for several Hitachi models made at about the same time.
Most of the time these sets develop a discolored area fairly large in the middle of the screen---a lot of them had a large red or pink oval area but other colors are possible.
This set uses a LAMP for the light source and it directs the light into the optical light engine--at the top of the engine is a 3 inch lens that the picture comes out of and is directed into the mirror which puts it on the screen.
Lots of these sets develop a "burn" inside the engine from the heat--there are a series of lens and baffles inside---even slight separation inside will change the color in some area of the picture.
I am sorry to give you bad news but I have replaced a lot of these engines under extended and when they were new mfg. warranty.
The part is no longer available from Hitachi new--the only way to get one is to remove the one in the set and have it sent out for "rebuild" and the last time I saw one the engine was over 600 dollars at the wholesale level not counting the fact that it is major labor to replace.
Find someone in your area familiar with Hitachi and this model and you will see what I am talking about.
Even though this is not good news, I think it is what your problem is.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Hitachi 60V500 60" Rear Projection...
I have a Hitachi 60V500A 60" LCD Rear Projection TV. I have NO picture or sound. I was told that I may have a problem with the PC board. Any estimate of what it may cost me to get it fixed?
Before going too deep into repairs, check to see if the Lamp is bad. If it is, the part # is UX21511.
I would estimate the cost of the lamp to be about 200.00 but the price could vary. Hitachi's Customer Service phone number is 1800-HITACHI.
I hope this helps,
Skyassoc
Oct 22, 2009 | Televison & Video
Hitachi 60v500a projection turns itself off
i have the same problem, did you ever get an answer?
May 31, 2009 | Hitachi 60V500 60" Rear Projection...
Have a green tint over 90% ot the center of the screen
I had the same problem with my 60V500A about a year ago. The screen got a red tint in the center and the image was fuzzy in that area. A new lamp didn't solve the problem. I did some checking and found out that the original light engine used in this model had a cooling issue that could cause the light engine to overheat and distort the LCD panels. My warranty had run out more than a year before this happened so I figured I was screwed since the light engine was so expensive. I decided to call Hitachi tech support and see if I could get a discount on the cost of a new light engine since the cooling problem was a known issue for this model TV. I calmly explained to them that I was aware of the cooling issue in the light engine and that I felt like a $4000 TV should last more than two or three years. Tech support gave me the phone number for my local authorized Hitachi service center and I gave them a call. Once the technician confirmed that it was the light engine that was the problem Hitachi sent him a replacement light engine at no cost to me. I was WAY past my warranty period so I still had to pay for the labor to replace the light engine. $300 for labor was a lot cheaper than buying a new light engine or tossing the TV and buying a new one. I have to say that Hitachi earned my respect for admitting there was a problem and doing what was needed to correct the problem more than a year after my warranty had expired.
Feb 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 60V500A
Good Day, artisticpool;
Suspect loose cable see picture:
If okay suspect light engine.
Good Luck, big IRISH.
Aug 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
60V500A Blue Spot
That is bothersome. We have not decided what route to take. It wouldn't surprise me if you called back and got a different answer.
Jul 24, 2008 | Televison & Video
Red spot Growing in the middle of my Projection LCD screen
We took in a 60v500a with the same problem, Customer bought a new set. We took hers apart. Here is what we found.
1 there is a squril cage blower and a small air duct that cools the lcd screens and polarizer lenses. Yes there are 3 polarizer lenses one in front of each LCD screen.
These start to overheat and discolor. Maybe the filter for the fan clogs up.
Don't really know.
You can pull the LE and vaccum the filter clean every 3-6 month.
You can remove the lenses and maybe the tv will look ok maybe not. I have read where some have had there repaired and now they see vertical lines in the screen. This seems to be a quike fix by removing the melted lens. Cool A.
Oct 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
