Question about Sharp (BQC-XGNV2U//1) Projector Lamp for XG-NV2U, NV3XU, NV3XB, PG-D210U
Sharp XG-NV2U projector not firing up
Our church just inherited a Sharp XG-NV2U projector. Even when the power cord is plugged in and the main switch is on, there is no power light and it does not turn on. We checked to make sure that the lamp was seated properly and the door closed. We also opened the unit and saw many boards and a metal case that said power supply but did not see fuse. Is there a fuse in the unit? If it is, is it accessible in the front or back inside the unit? Where might it be located?
Your help will be very much appreciated.
Orel
  • Anonymous Feb 01, 2009
    same problum
  • Maurice_V May 13, 2009
    No power. Changed bulb but still the same thing.
There is a fuse in the block where the power cord plugs in. you have to disassembe the unit and remove the circuit boards to get to it as far as I can tell. the fuse is a 250volt 5amp ceramic fuse 20mm. I have the same problem and just found the blown fuse but I am still looking for the replacement fuse to buy.
jeff
Posted on Sep 04, 2010
Yellow circle on sharp pg-d210u projector
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years,
and the price is USD190
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Apr 04, 2014 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Who made the orginal lamp for the sharp xvz20000
AN-K20LP,SHP95, 100% Original lamp
USD200
Have a nice day!
Jerry
Lampdeng Limited
Feb 23, 2014 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Sharp vision overhead projector lamp will not turn on
Have a nice day!
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jul 06, 2012 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
I just bought a used XG-NV2U and it is blurry,
Have a nice day!
Jerry
Lampdeng Limited
May 14, 2010 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Looking for a sharp pg-d210u projector manual
Sharp PG D210U projector has yellow oval when viewing input and a black oval when on the blue sheet. What is needed to correct this?
Feb 28, 2010 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
My sharp xg-nv2u will not display my laptop picture now. It worked fine a day ago.
try booting up your lap AFTER you have plugged in the projector and booted up the projector.
See how you go
Oct 30, 2009 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
I inherited a Sharp XG-NV2U LCD projector. When I turn it on I get a blue screen with a blurry white square in the middle, which I assume is the menu. Have adjusted focus but doesn't change. Any...
lcd panel or palarizer is failed
Have a nice day!
Jerry
Lampdeng Limited
Mar 28, 2009 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Where are the fuses in a Sharp xg-nv3xb notevision3 projector
Main line fuse is on the board where the ac cord plugs.
The caps in the power supply usually leak and explode after 5 years, blowing the fuse. Solution is to replace the power supply and lamp ballast boards. Expensive repair.
Nov 09, 2008 | Sharp Notevision PG-A10X Multimedia...
My sharp xg-nv2u will not turn on. i have the power cable plugged in and everything is on....
1.Open the lamp cover and reinstall.
2.open the projector and check the Power Supply
3.check fuse/ thermal cut off switch.
Viren
Jul 13, 2008 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Sharp (BQC-XGNV2U//1) Projector Lamp for XG-NV2U, NV3XU, NV3XB, PG-D210U Logo
265 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
