where do i take it to get it fixed..mine was dropped and it says it cant read the disk where do i take it to get it fixed..mine was dropped and it says it cant read the disk
There may have been shock inflicted on the PSP causing it to break the LCD which is fairly easy to do as they are fragile. If you are courageous you can buy a new LCD screen for it of the internet then open the PSP and swap the LCD screens.
due to loose contacts of the Screen with Mother of board of PSP this issue occurs. Just Hold the screen put the thumbs on Display and try to adjust by slightly moving on all corners it can be fixed.
if it possible open the cellphone and check out the contacts between screen or display to mother board then repack it. your issue should resolve.
Unfortunately, your son may have damaged the back light in the PSP. The only way to repair this is to take it to a local repair shop and have them remove the old PSP screen and put in a new one. It is possible that the connection to the motherboard and the screen has become looser, but I want to prepare you for the worse.
You might have a brick psp, you need to reflashing your psp.. If you have Custom firmware installed e.g. M33, you can try this first;
try to boot your psp to recovery menu, ( hold R-trigger when turn on your psp), you should see M33 recovery menu, then select "advance" then "Format flash1 and reset setting", if it does not work you need pandora battery for unbricking your psp. or you may consider to sending it back to Sony for repair.You can call SONY support at 1-800-345-7669.
Hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
I don't want to be the person to give bad news, but after reasearching your question for you it sounds like you son broke the psp. The color screen behind the lsd screen is damaged and usually cannot be repaired by an unqualified person. If you were to bring the system to be repaired between labor and costs, it may be cheaper to buy a new PSP.
Hopefully, depending on how long you have had the PSP you may be under a warranty.
What I suggest is to call Sony. See if you are under warranty, and have it replaced for no cost to you. Otherwise you will have to purchase a new PSP.
The number for Sony is found on the back of almost all of the psp video game manuals.
I hope I was able to fixya problem, and I wish you and your son Happy Gaming!
its either your psp is bricked(rendered useless..as entertaining as a brick becuase it wont do anything at all.) or screen came unplugged. try turning it on then turning the sound all the way up and see if you can hear the normal sounds. if you can either the screen is unplugged or ruined. if you cant and it turns off by itself then you have a brick.
hi there i have had this probertlem what you have to do is press every button at once if that does'nt work then try turning up the brightness on the psp
Have you inserted the game disc UMD into the PSP itself? You have to wait a few seconds after you turn it on before the game icon will be visible in the main menu screen before you can access the game. When it's active and you have the game icon selected press the "X" button to start the game.
if the psp screen is anything like a laptop it will have a backlight that lights up the screen what can happen is you can break the light and while you will still see things on the screen when you look closely but it wont be illuminated. i had a friend that dropped his laptop and smashed the backlight he sent it away and got it fixed
i suggest you send it to sony to get it fixed
Has the system been dropped? It sounds like the connection to the screen has been broken.
