Question about Whirlpool Calypso GVW9959K Top Load Washer
Problem with washer
The washer, the calypso, has the extra spin on and it will not cancel, i can press start and it will go through the 8 minutes of the spin but it will go back to 8 minutes for spin, it does this continually. what can i do to fix this problem?
  • Jenny Morlock Jun 01, 2007
    i have also unplugged it for about an hour
  • 87 Answers
You probably have a bad control pc board
Posted on Jun 08, 2007
Calypso has unbalanced "L5" message
LS is a "Lid Switch Error"
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display. If opening the lid or pressing STOP/CANCEL does not clear it, unplug your washer for 5 minutes.
Here is a link to a PDF manual for it also.
Calypso Manual
Nov 21, 2010 | Kenmore Washing Machines
Whirlpool calypso top load washer GVW9959k stuck on FL
FL=FLOOD CONDITION
I bet I know what the root cause of the problem is. TOO MUCH DETERGENT. Why do I yell that? OK here is what happens. Suds make the computer monitor work overtime to wash the clothes. The the computer measures the amount of water being used. The computer is also trying to correct the suds problem by adding water during hissy-cycles. (I call em hissy cyles.) Solution: Clean the soap dispencer use HE soap and use the right amount which is:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Calypso Service Manual
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer is not washing clothes or spinning; getting LF error message. Water is going into the machine but no washing action.
Hi There
I'm Sending you the fault codes. Hope this helps you and get you in the right direction.
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Cycle Problem
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD and OB on Calypso
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating
pressure switch resets.
OB:
If the motor controller detects an unrecoverable off-balance condition, the machine controller
will shut down and display an “ob” for off balance.
The lid switch must be opened at least once before restarting the cycle, if this condition
occurs. Opening the lid will allow the customer to view and redistribute the load.
Basically, it sounds like your drain pump is bad or clogged, and the extra water is throwing the spin cycle off balance
-Perry
800-Appliance San Diego
Dec 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
