Question about Microsoft Windows XP Home Edition
Xp not installing
Im using hp 6710s laptop with redhat linux 5.2 now im try to install xp in it but after booting it shows there is no hard drive in ur system?
plz help me
  • 66 Answers
First configure your hard drive in the bios set your harddrive as primary drive then configure the booting setup you must boot first the CD ROM drvsave setting and exit. Then if you have a bootable disc installer for XP any OS insert in in the CD ROM drve. wait for a while then follow the instruction that goes out in the desktop.
Posted on Jan 09, 2009
HP proliant DL380 gen4 PXE-E61, when trying to install redhat and solaris.
First, it's not booting from a CD or Hard Disk if you've reached that error. The 'last-ditch' effort to boot is to attempt a PXE boot from the network card, but your Ethernet cable isn't plugged in. Unless you know you've setup such a PXE boot server, you'll want to check the BIOS settings to be sure the CD-ROM is set to boot first, followed by the Hard Disc. Be sure you have Disc 1 of the Linux installation set in the CD-ROM Drive and reboot. If you don't get the install screen, you may have another issue (bad CD-ROM Drive, bad cable/controller, no power to CD-ROM, etc.)
Another note on the DL380, if there is a RAID controller, you'll need to setup the RAID before installing the OS. You'll want to make sure your hard drives are properly installed and aren't failed. The RAID configuration screen will verify the RAID status once it has been initialized, which will somewhat verify the drive status.
Nov 12, 2013 | Computers & Internet
My hpv165w 4 gb pendrive shows empety
Format the usb key with HP USB Disk Format Tool.
Then download Universal USB Installer (Pendrive Linux) which has support for booting/installing Windows Vista, 7, and 8
Mar 29, 2013 | PNY HP P-FD4GBHP165-EF BLUE HPV165W USB...
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
Im using hp dv6700t laptop,i want to install xp on my laptop
Your laptop has a SATA hard drive and windows XP doesn't recognize those drives cause the operating system came out before those drive were made.
Follow these steps I found thru google to get windows xp sp3 to recognize your drive:
http://en.kioskea.net/forum/affich-39282-xp-can-t-recognize-hard-drive-for-os-install
You'll have to use a program to do this but people explain how to do it on that page plus the program is free.
Jun 25, 2009 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Unable to connect to the internet in Redhat Enterprise Linux 5
Get the drivers for your WiFi card for the correct edition of your RedHat. Wireless card may be incompatable with red hat.
Apr 11, 2009 | Red Hat Enterprise Linux ES Basic Edition
HP Pavilion ze5500 - Laptop won't recognize hard drive.
Hi. Once I had this similar problem with a HP Pavilion dv9000. "No Operating System"; "Windows Recovery Console cannot continue because there's no HD present..press F3 to Exit". No progress with Safe Mode nor Command Prompt, etc.
Then I went to the Bios, change tab to "System Configuration" and change the "Sata Native Support" to disable, whitch says that by changing to disable the HD would work better if the Operating System are Win2000 and Win9x.
Hit "Safe and Exit" and the computer started normaly!
I relly don't know how or why. It just work.
I don't know if would work for Linux (mine had Windows XP) and don't know the Bios view of your laptop. But you can explore and give it a try.
Hope this helps.
God Bless You!
Jan 06, 2009 | Computers & Internet
Laptop boots but I get a blank screen
your os (xp/vista/linux) is dead (or your hard drive is. try reinstalling whatever you use, and if it won't install then get a new hard drive. they are around a dollad per gigabyte now.
Jul 22, 2008 | HP Pavilion dv9000z Notebook
Linux installation
i don;t know redhat but there shoud be a no acpi option on boot , try that.... Anyway, the best thing that u can do is to go on redhat support or comuity formuns, and they will guide u ...
Mar 25, 2008 | Computers & Internet
Unable to install linux
The Acer Aspire 4710 uses a SATA hard drive. Unfortunately Redhat Linux 9.0 does not have SATA support (uses the 2.4 kernel). You will have to upgrade to something recent like Fedore Core 7 or Ubuntu 7.10. Hope this helps.
Dec 25, 2007 | Computers & Internet
Not able to install linux
My guess is that when installing XP the option to format using NTFS was accepted. You should get a (Windows 98) DOS start floppy/CD and re-partion and format the drive before booting Linux install from CD/DVD
Microsoft Windows XP Home Edition Logo
89 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
