Question about Hotpoint Aquarius WF000 Front Load Washer
Water still leaking
Hotpoint WF445.
Have checked the pipe, it is clear and water does not seem to be coming from there. Seems to be coming from under the drum as the concrete below is wet. Will we need to get somebody out to fix this? I am confident I can repair this myself if you can keep giving me clear instructions.
Thank you
    Novelist:
    Habit-Forming:
  • 78 Answers
The pipes beneath your house may wear out and start to leak. Slab leaks create water build-ups underneath your concrete foundation. To repair the concrete crack (hairline crack) first of all clean the concrete surface, use chisel and hammer to make the surface rough, it will make the concrete-patch bonding strong. Now clean with vacuum and broom to clean all dust and debris. Apply concrete sealer product over the crack. Fill the crack properly with the help of trowel and also make the surface smooth. Now let it be dry. If you use oil-based concrete sealer, you can coat twice or thrice. It will make the concrete floor water resistant.
Posted on Sep 19, 2018
  • Hotpoint Master
  • 3,463 Answers
Look at and examine the door seal closely for any sign of a hole or tear in it.
If none is visible then it could be the clamp or spring that holds the seal to the drum front that is causing the prob..
Other than that , there could be a crack or hole in the container front.
Posted on Jan 08, 2009
SOURCE:
Does the hotpoint Aquarius wf445 have a filter as I have water coming from underneath washing machine please help
More than likely it's a leaky pump or a seal that's gone out. If it's overfilling then it could be the water inlet valve. Repairclinic.com has a lot of useful information and they sell replacement parts as we'll.
Apr 13, 2016 | Hotpoint Washing Machines
Hi I have a Hotpoint Aqurius WMA 37 model. At first it was not spinning properly, and now its started to spin but there is alot of water leaking from the door as well as from the dispenser drawer, it...
I would first check the state of the drum by taking the back off but-
REMOVE POWER BEFORE YOU DO-
The whole of the support mechanism should then be visible- the 'spider', the belt, the motor AND the shock absorbers/dampeners. It could be that something has broken and requires fixing (first).
As for the water coming out of the dispenser drawer I would also check if it is absolutely clean and clear, especially the softener bit. Following is my standard/generic document, copied and pasted ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catch underneath or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover on it which you must remove to expose the little stuck up pipe/tube. This is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Feb 14, 2011 | Hotpoint Aquarius WD640 Front Load...
Machine does not clean clothes the machine seems to work ok but the washing feels stiff and there is sedment on the washing the machine is a hotpoint ultima 18 months old.
Try cleaning out the dirty water pipe. Mine was completely blocked up with scale and soap powder. We used a coat hanger and went from the out side as well. The water now pumps out completely without leaving any left under the drum
May 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Water leaking from Door and Draw from Hotpoint Aquarius Extra
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Drum wont empty...have checked pump, seems to be working becasue some water is being pumped out..have checked filetr to pump and removed a couple of small buttons..outlet hose seems fine because initial...
It obviously is related to the pump and outlet hoses.
If it is a tap in waste then check for obstruction there,
Remove drain hose completely and run water though it to make sure it is fully clear.
Check inside the pump itself for any obstruction , if you are satisfied that every thing is o/k, then as a last resort, fit new pump.
Plz leave feedback for this solution.
Thanks.
Dec 14, 2008 | Hotpoint WMA35 Front Load Washer
Hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WF840P washing machine
the pump is blocked... at the bottom back there is a plastic cover, remove this and the pump is located on the back right hand side.
tilt washer far forward, place a bucket under to catch water and remove pipes.
once cleared, test again, if still no joy then you just need a new pump, but this part is a work horse so i would assume it is blocked with something like a baby wipe or babies sock (usual suspects)
Jun 23, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Aquarius wf 541
Check your drain pipe behind. This is supposed to be approx 3 feet above ground level; then the hose goes into the stand-pipe without being too tight. If this does not work, click "thanks for trying"; your prob will be back for someone else to solve.
Jan 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD64, leaking water from soap drawer
your condenser is blocked,you might be lucky and get away with just cleaning it, but most of the time it is just best to change it. You will have to take the back off again it is the plastic component with the fan motor attached, disconnect the 2 black tubes to it [note where they come from] unscrew the 3 bolts at the bottom , disconnect the wires going to the fan motor. If you are going to change the condensor you will have to take the fan motor off aswell MAKE SURE YOU DISCONNECT THE MACHINE FROM THE MAINS. GOOD LUCK
Aug 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
99 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
