Question about HP TouchSmart IQ770 PC Desktop
Hp IQ780A has a2discs stuck in the dvd drive
HiHp IQ780A has 2 discs stuck in the dvd drive. Drive working but not able to eject the discs. Child forced the second disc into dvd drive.
I've been seeing some message traffic on disk NOT ejecting where I was having a problem with the DVD not staying in - it would keep ejecting. If I was persistent enough (which I was) it would eventually stay in. Seemed like a break-in deal because now I can insert a DVD 99% of the time without it auto-ejecting.
So this morning I was surprised when I stuck my DVD in the drive that it wouldn't eject it. I did notice that it seemed to hang a wee bit going in.
Now, my disk wouldn't eject. Back in the day I used to fix computers (A+ Certified) so I figured I'd give it a whirl - I noticed that the disk would come try to eject (coming flush with the disk insertion point) but would then get sucked in.
I grabbed a jewelers screwdriver, put pressure against the drive opening so that the screwdriver wasn't in the way and hit Eject. When the disk was flush against the disk opening I pushed against the top of the DVD (from the front to the rear) and jammed the DVD so that it couldn't go back in - it tried a couple of times and gave up. So now my DVD was just sitting at the opening... I grabbed some tweezers - squeezed tight and successfully pulled out the DVD.
To my surprise a second DVD popped out - I'm talking it got thrown out of the computer onto the floor (imagine my surprise). Fortunately, I didn't damage the DVD extracting it and it's been happy ever since.
Moral to the story - the HP TouchSmart will allow you to insert a DVD when there is already one in it. If you get even the slightest resistance (there was some) assume there is a DVD left it in and be sure to eject it before inserting the DVD.
Bill
Posted on Jan 18, 2009
    Novelist:
    Scholar:
  • 70 Answers
Woah! You don't want to hear this but forcing a second disc into the drive has probably destroyed the drive read head. They are pretty tough and it might be able to survive but you will most certainly have to dismantle the drive to remove the DVD and not create any more damage. Kind of like scraping someone elses car in a parking lot. More damage is done when you try to back off of the other car than the initial hit. (not like that's ever happened to me :) )
Posted on Jan 08, 2009
Disc inserted improperly now stuck
Carolyn:
Take a butter knife (not a steak knife) and push the diskette into the drive the rest of the way, and then eject it.
Jul 12, 2015 | HP 19-2014 All-in-One Desktop PC - ENERGY...
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
Cd stuck in E: drive on my HP TouchSmart 300 PC
You will have to manually eject the disc. take a straightened paper clip and find a little hole near the slot where the disc goes in. Insert the paper clip and it should eject the disc. If there is no hole, you may need to access the disc drive by removing the back panel and/or disc drive faceplate.
Apr 12, 2013 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
Dvd drive won't open
Might have a stuck disc. Use a straightened paper clip in small pin hole of the CD drive to manually eject.
Nov 14, 2012 | HP Compaq Presario SR1920NX PC Desktop
Disc Drive
If the eject button is not working, assuming this is a Windows based computer, click on start icon, your start menu will display, on right side under your user icon you should see Computer or My Computer, click on it.
You will now see all drives in your computer. Right click on your dvd(optical) drive. You should see an eject option.
If this dosen't work, close to the eject button on the drive is a tiny hole that will accept a paper clip, carefully push clip into hole until drive ejects.
Feb 13, 2012 | HP Computers & Internet
DVD disc stuck in built in dvd on LG LCD TV/DVD combo
1. Power the set down.
2. Hold the eject button on the drive while you plug it back in and power it back up.
That should eject the drive.
Aug 29, 2011 | LG 32LG40 32 in. LCD HDTV
Disc did not come back out on disc player
Do you mean your disc is stuck in the drive?
If so Look at the drive there should be a tiny pin hole near the eject button, insert a needle (safety pin, sewing, etc.) into the pin hole and push this opens the drive.
You can also try opening my computer and right clicking the DVD drive and select eject.
Jan 19, 2010 | Dell SideBay/Fixed Bay DVD+CDRW Combo...
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Stuck DVD tray
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Jul 21, 2009 | HP Pavilion DV5234US Notebook Laptop
Manually eject DVD
Hi there
these tv's are prone to this problem.
there are two solutions.
!. Unplug for a day and then try again. (Seems odd but folk say it works.)
2. There should be a small hole beside the drive slot. unfold a paper clip and push it into the small hole if you can find it the disc should then eject.
PS there is a firmware update on the internet that addresses these problems as the set will keep trying to read unreadable discs constantly.
Hope that helps.
May 01, 2009 | Televison & Video
HP TouchSmart IQ770 PC Desktop Logo
879 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
