Question about Ricoh Aficio 2015 Copier
Sc 481 on my ricoh aficio 1224
Can you help me with the discription for the service code SC481 on my Ricoh Aficio 1224c unit?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
sc 481 on my ricoh aficio 1224 - moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Posted on Jan 08, 2009
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh 1224c Error SC-421 Please help
Hello!
Well, that is not an easy error. Your machine is detecting a short circuite in the discharge plate. It could be just a defective harness between the High voltage supply unit and the BICU.
So... The best advise i can give you is to call your technical support.
Jul 12, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh aficio cl1000n sc481 error message
sc 481 is the OPC belt error. check the opc belt unit. it is also called rum unit. i think the belt is worn out and needs replacing.
Jan 06, 2011 | Ricoh Aficio CL1000N Printer
I am getting SC412 on my Ricoh Aficio 1224C, how do I fix it, and what is it?
sc412 on a 1224 is 2nd transfer (paper transfer) disconnection (+).
The possible causes are:
- The right cover is open
- The transfer roller contact mechanism is broken
- A bad high voltage supply board
- A bad BICU-to-HVSB cable
Parts for the 1224 will be obsolete soon if they are not already, so you're probably better off upgrading to a newer copier if closing that right cover and resetting the machine doesn't fix it.
May 18, 2010 | Ricoh Aficio CL7000 Laser Printer
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 1224c error code SC 544
Well, I have no idea why changing your password would affect it this way. the code you're experiencing is a fuser warm up error, due to blown fuse, thermostsat, possible power supply prob...regardless, it can only be reset by a service tech in service mode once the problem is fixed. Sorry.
Mar 05, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Jan 09, 2009 | Office Equipment & Supplies
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
Ricoh Aficio 2015 Copier Logo
633 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
