Question about Panasonic SC-DK10 System
NO disc My system has stopped playing any cd's, DVD's etc. When I try to play the system displays that there is no disc after making a few attempts to read it.
  • Anonymous May 14, 2008
    My system will on only play the dvd and videos from it but it stopped playing all music cds? Displays no disc.
  • gbell210 Jan 25, 2009
    Mine won't read anymore either, but I may have narrowed it down to the motor itself. With the cover off, I've found that when it tries to read the disc, the disc isn't spinning. If I give it a push to start spinning, it will read the disc. So I think it may be the motor that has gone out, but I haven't verified this yet. I need to find a place to get the part.
How much does the Spare Lens will cost. As my SCDK10 has stopped readign the CD and DVD. Will replacing it reolve the problem, if yes please let me know the Cost of LeNS at the earliest at mankum321@gmail.com
ANIL PHILIPS
Posted on Jun 21, 2009
The same happened to me recently, you need to go to your electronic store and purchase a CD/DVD laser lens cleaner, put it in run it problem solved
Posted on Jun 01, 2007
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Plays CDs but not DVDs
I had the same problem, don't try to hard it won't solve the problem. Just buy a new cheap one and it even will read more formats.
Mar 12, 2007 | Panasonic DVD-RV31 DVD Player
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
Problem with original dvd
Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
Dec 15, 2005 | JVC TH-A5 System
Panasonic SC-DK10 System Logo
337 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
