Question about Panasonic KX TC1402W Cordless Phone (KX-TC1402W)
The phone doesn't work
My problem is that suddenly the phone didn't work anymore. A few months ago When I disconnected the AC adaptor and reconected it after a few minutes the unit worked, but if I used it with a call, after a few minutes the main unit (not the phone) turned off. and next It was impossible to turn on putting the phone on the main unit to replace the code. But now the phone can't find the main unit (the phone works, but the main unit can't link with it). Somenone told me that probably I have to resoldering the microprocessor in the main unit, but i'n not sure about that. Can you help me? Thanks.
  • 8 Answers
SOURCE: turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Posted on Oct 09, 2007
SOURCE: PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Posted on May 02, 2008
tech48
  • 624 Answers
SOURCE: SA HE200 Code F70 problem
The F70 error code is not for the replacement of a fuse. It is an error code for the microprocessor having trouble communicating.
Try leaving the unit unplugged overnight and then plug it back in again. This should clear that code.
If it does not clear the code, try doing a hard reset with the unit NOT PLUGGED IN.
You would need to use a small metal pick or small flathead screwdriver and use a jumper to ground the pick/screwdriver to the chassis of the unit. Then you slowly run that pick over each pin of the micro, thus grounding every pin one after the other. This way you are sure to ground out the reset pin.The unit must not be plugged in when you do this. It will clear all memory and settings.
Without having this unit in front of me to properly troubleshoot with the proper tools, anything told to you is only a guess. Unless the person advising you has direct experience working on these units, they can not possibly know the solution to this problem.
I work at an authorized Panasonic service center and have never seen one of these receivers with that code and all it needed was a fuse replaced.
I have seen them needing the microprocessor replaced, but that is not something you could do yourself without the very best soldering skills. The microprocessor is a surface mounted component with 80 pins and is a very difficult component to replace. You can see it on the display panel near the middle of the board.
That code is no guarentee that the micro is bad either. if it doesn't clear the code by the way I have told you above, it needs to be serviced. Like I said, nobody can troubleshoot the communication of the micro without an O-scope, schematics, and a very good knowledge of how they work.
I think the previous service center charged you for a fuse and all the did was a hard reset of the unit.
Let me know how you do with this solution and please do not rate it until we have had a chance to explore other options. I actually have repaired a couple of these before.
Dave
Posted on Jul 02, 2008
SOURCE: On my DMR-ES35 Panasonic after perfect operation for 18 months, I'm getting a NO READ message, on disks already recorded on this unit,and several new disks of different makes. The main sympton now is
Same problem. "NoREAD" after about 15 months of moderate usage. Cleaned laser eye thoroughly. Solution is a class action lawsuit against Panasonic.
Posted on Nov 08, 2008
  • 9 Answers
SOURCE: Panasonic SC-PT950 Wireless Speakers Question
It is pairing process again.
Inside the Main set operating instruction can help you solve it.
Posted on Jan 06, 2009
MY PHILIPS SA6158/02 DOESN'T OUTPUT ANY SOUND!!!
Insertion and removal of the adaptor may have damaged the "jack". You may have to do some disassembly to find the cause and repair it.
Aug 25, 2017 | Philips GoGear SA6185/37 Digital Media...
Samsung Galaxy S2 fell into water wont turn on ! PLEASE HELP
You should not have tried to use it right away. You should have immediately pulled the battery out and then blow dried it and put into the rice bag for 24-36 hours. Because you tried to use it is shorted out. You will need a new phone as it is probably not going to be able to be fixed. Sorry!
May 06, 2012 | Samsung Galaxy Cell Phones
Compaq Presario V3000 SUDDENLY DEAD
Remove the battery and try on the AC adaptor only. if it still doesn't work try a new adaptor.
Apr 06, 2012 | HP Compaq for Presario V3000 Motherboard
I tried to charge my psp with a few 9 volt batteries and i think i fried the motherboard it wont turn on with the battery or without the battery and connected to the AC adaptor. When i try to plug the AC...
You could try another battery.But if another battery doesn't work,sorry mate I think it's dead.In future make sure you only use what you know is compatible,also NEVER try to run the PSP with the AC adaptor without the battery in.The PSP safety and support booklet states: Do not use the PSP system with the AC Adaptor when the Battery Pack is not inserted in the system.If the AC Adaptor is disconnected suddenly,it may result in damage to the system.
If it is the motherboard that's burnt out I think you can replace it but they're expensive I think,I saw one for a PSP1000 for
Oct 04, 2010 | Sony PlayStation Portable (PSP) Console
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Is my AC Adapter for HP Deskjet F380 out of order?
You can contact PRASHANT 9820930880.
I found this on the net while searching for the adapter. Placed the order just now. Not sure how genuine he is
we have hp all in one adapters model f/310/325/335/340/350/370/378/380/385/388/390/394 @400RS. CONTACT : PRASHANT 9820930880
Jan 05, 2010 | HP DeskJet F380 All-In-One Printer
My XSA 975 telephone was accidently disconnected from the power outlet. When reconnected I found cannot dial out but can receive calls inward. I have tried disconnecting the AC adaptor and reconnecting...
I unplugged the AC Adaptor from the wall socket and left unplugged for an hour or so (a few minutes as per the trouble shooting advice page in the instruction manual did not work). I then reconnected the adaptor to the power and the phone returned to normal service.
Dec 04, 2008 | Lands Phones
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
Ac adaptor
my etec mp3 player will turn on when i plug it into the computer but when i disconnect it it wont turn on
Apr 11, 2008 | Computers & Internet
Panasonic KX TC1402W Cordless Phone (KX-TC1402W) Logo
35 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
