Question about LG 42LC2D 42 in. LCD HDTV
Tv switches on, on its own
Whilst on stand by during the night tv turns on itself channel 8 fuzzy screen and sound turned right down to 0. this has occured 3x this week
  • mark_tull1 Jan 08, 2009
    thanks i will try that
    Novelist:
  • 140 Answers
I do not know how old your tv is, but I can tell you that if it is more than a couple of years old, the back cover needs to be taken off and blown out with clean compressed air. If your tv has quiet cooling fans on the back, they are notorious in all plasmas and lcds 32" and above for attracting dust and lint from the ambient air. This along with moisture will cause the dust, lint and moisture to settle on critical components that cause tiny static discharges between components that can produce what you described. Another thing is and this is from my own experience is that even the tiniest pest like a roach or a spider, like I said depending on the age of the tv, can cause similar problems my traversing across the components. I had an RCA that would turn on by itself and change channels by itself. All in all the one thing you can do yourself is clean it out of all dust and debri. Good luck and God bless you. Robert
Posted on Jan 08, 2009
My swann 8-camera system, each night goes into the "no video Mode" each night and comes back on in the daylight.
It's going into ir sound like you are not supplying enough power to the cameras or you might have a timer on you system
Oct 11, 2016 | SWANN H264 8 Channel Dvr W500 Gb Hard...
Hitachi 46w 500 screen says locked
reset the tv by pressing the reset button.
Aug 21, 2008 | Televison & Video
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
cable.
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link http://eko.4shared.com/ and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Bush free view system switches on during the night
This doesn't sound like any problem i have heard before, there are usually other problems associated with it, your probably better off turning it off at the mains anyway but if you don't check the batteries in the remote and that the remote is away from animals that could accidently turn it on
kind regards
Dec 22, 2008 | Televison & Video
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
Dec 15, 2008 | Proscan 32LA30Q Television
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Jul 06, 2008 | Televison & Video
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
T.V. abducted by aliens!
The controller eprom is in a fatal error and cannot be repaired. The pink indicates that a channel in the LVDS interface is gone and that cannot be repaired. This most likely is caused by a failure in the LCD module itself which then shorted out the driver on the main board. If your unit is under warranty, take it in as the LCD panel itself should be covered.
Good luck
May 15, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Same channel on all channels
Yeppers it certanly sounds like the tuner control curcuit or the tuner itself is bad. With the back off the set and the tV on, if you tap on the side of the tuner does the set start to work? if so the tuner has to be replaced
Sep 25, 2006 | Sharp 32R-S50 32" TV
LG 42LC2D 42 in. LCD HDTV Logo
91 people viewed this question
Computer Repairing
Computer Repairing
