Question about LG AP-40SA10B TV Speakers
Wireless home theater system
The wireless transmitter in my LG home theater system does not recognise the back speakers. It flashes blue (instead of constant light) and makes a horrible clicking noise.
4 Suggested Answers
SOURCE: sharper image wireless speakers, model CT 413,
My speakers were working fine on my TV, I disconntect them, then when I re-connected the transmitter no signal is received and nothing is heard via the spearkers either.
Posted on Aug 08, 2010
  • 4070 Answers
SOURCE: audio unlimited wireless speakers quit working.
Hi! The problem will be on the wireless speaker itself. I'm afraid that this is unrepairable for this units are disposable. Hope this shed some light.
Posted on Sep 16, 2010
  • 85 Answers
SOURCE: Bought a LG Blu ray
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Posted on Jan 07, 2011
  • 8546 Answers
SOURCE: I was told most home
You don't name the product so I can't steer you to the manual WHICH YOU SHOULD BE READING BEFORE COMING HERE FOR ADVICE.
"5 ch direct mode" is usually for an external device that takes high-end multichannel audio sources like SACD, Dual-Disc, DVD-Audio; and decodes the bitstream to (usuually) 6 distinct analog channels for listening. They did this to prevent direct digital copying of the audio. Anyway, when you select that mode on your receiver you BYPASS all of its digital sources and all digital processing and only those analog channels connected to the dedicated 5.1 inputs will be heard. Does that explain it?
Posted on Sep 01, 2011
0 characters
1 Points
How do u connect the wireless speakers ?
Not much info here, Anon. So, I'll tell you what I know about wireless speakers generally. I have a Samsung home theater which has wireless surround speakers. However, "wireless" simply means they're not wired to the receiver. Wires are needed, however, to run from the surrounds to a unit (receiver is all it is) which must be plugged into a regular wall plug. This receiver picks up the surround signals from the theater and then transmits them to the speakers.
Presumably, you have this wireless receiver unit which matches your speakers. . . If not, it may be something you must buy separately. I don't know what type of electronic equipment you're talking about here, but what I just described is the norm for home theater. The only truly "wireless" speakers I know of are battery powered and are for patios, porches, decks, etc. so that you can listen to your music outside. They are tuned to a particular radio frequency - like a walkie talkie.
May 23, 2016 | Speakers & Subwoofers
The blue light on the transmitter is not coming on. It had begun to alternatingly be on/turn off. What is the problem?
Check that the transmitter AC power adapter is fully inserted into the wall outlet and the power cord from the AC adapter is firmly connected to the transmitter power input jack. So if you
Jan 05, 2011 | Cables Unlimited Audio Unlimited 900MHz...
I'm intrestered in buying a samsung home theater system model number HT-2320 1000 watt system. the problem is that thje information provided about the system states that this system is wireless eliminating...
you need a SWA-4000. At the moment it costs around £99 and its only for the two rear speakers. However its well worth the buy in my opinion ( if its realistic money wise! )
Nov 26, 2009 | Speakers & Subwoofers
Sharper image wireless speakers, model CT 413, were working fine. today, the blue transmitter light isn't on and nothing can seem to make it transmit. suggestions?
Nov 25, 2009 | Speakers & Subwoofers
Wireless digital transmitter doesn't work
I'm having this same problem; it worked all ok in the beginning then one day it didn't and no matter what I try it doesn't seem to connect. Similarly im getting the W1 flashing and even when I take the receiver and move it closer (even within a few feet) it still wont pick it up. I've removed the wireless home phone and baby monitor from within the room without any result. I cannot think of anything else that could be interfering. Any advice or resolution would be much appreciated.
Oct 06, 2009 | Panasonic Speakers & Subwoofers
How do I add an outdoor wireless speaker to my Sony home theater system that has WIRED speakers?
An outdoor wireless system operates from a base unit that is connected to your sony using RCA cables. If your system has a "Front Main" rca output on the back (red and white plug in points) use those. If you dont have a main output look for a "Tape 2 Monitor" or "Rec out" Those outputs will allow you to listen in another area where the wireless speakers are when the same thing is on in the main area. If you want to be able to listen to wireless speakers without the main area on, your system needs to have a "Zone 2" output.If you need further clarification on this, post a comment and I'l help some more. Hope this helps
Jun 21, 2009 | Speakers & Subwoofers
Wireless speakers AW872 transmitter won't power on anymore
I have the same set of speaker and had a similar problem. what I did was disconnent and reconnect the transceiver (sort of a reboot) and then powered everthing back up and that solved my problem.
Hope this helps
Dec 23, 2008 | Acoustic Research 900MHz Wireless Stereo...
Can't get the bose cinemate to work all hooked up fine get static coming through them upon connection but then nothing????
Never buy a wireless speaker system! Too susceptible to interference, and the RF transmitter/receivers will drift off frequency in a short time, leaving you with perfectly good but useless speakers. If it's a used system, there's not much you can do. If new, of course you can take it back and get a REFUND - don't exchange them for another wireless system. Run wires, live with the mess and enjoy proper performance for years.
Dec 13, 2008 | Bose Cinemate Digital Home Theater System...
Problem adding wsp155 wireless speakers.
You must check with the instalation gude for the wireless speaker to see if the connection to the reciver is a high impedence or low impedence... If its like most wireless set-ups its going to be a high impedence output from the reciver to the transmitter part of the speakers. That would be from the RCA jacks in the back of the reciver maked line out or tape out. If you want to use them for a specific speaker output , some recivers have an output jack that would be labeled center sperker out but would be an RCA type jack ect ect. If your reciver dosent have that you can in a higher end audio store get an adaptor to convert the speaker output to a high impedence, But I dont recomend that as some of the adaptors do cause excessive strain on the output section of the amp or reciver.. If you buy a good one though you should be fine.. You get what you pay for.. Good Luck
Aug 06, 2006 | RCA WSP150 Main / Stereo Speaker
LG AP-40SA10B TV Speakers Logo
Top LG Speakers & Subwoofers Experts
Lawrence Oravetz
William Alequin
Are you a LG Speaker and Subwoofer Expert? Answer questions, earn points and help others
