Question about GE GSS25LGM Side by Side Refrigerator
Best way to hook up the water line from washing machine fawcet...
Use a tap in or change the fawcet to one with valve inline adapter? thanks
  • 333 Answers
Under the sink use the screw down clamp that you get with the fridge. Just tap in to your cold water line that is the best way.
Posted on Jan 08, 2009
Why is there no water in tub during wash cycle?
Check water feed pipes, taps/fawcets possibly the pump not working.
Jul 21, 2014 | Kenmore Washing Machines
Kenmore washer water not filling
there is a inline mesh filter at the tap end of the hose but it is more that likely that the tap washer need replacing
it is possible that the inlet solenoid valve is not operating properly
if you have separate hot and cold water hoses and taps then either tap should produce a full flow when set if no taps get a full slow when selected , indicates a problem power board
Nov 05, 2017 | Kenmore Washing Machines
DOES MY WIXL143S INDESIT USE HOT OR COLD MAINS
That's easy to tell- if it has 2 inlet pipe/hose connections at the back (as opposed to the outlet pipe which is permanently connected to the washer and hooks over the outlet drain) then it is a hot and cold fill. If there is only one inlet pipe it is cold fill only. Either type HAS to have a cold fill supply- to lower the temperature of the hot water for cool washes AND for rinsing which is normally cold water only.
If you have only a cold water tap/fawcet available for the washer and it is a hot and cold fill you will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Hope this has clarified!
John C
Oct 29, 2011 | Indesit W 123 Front Load Washer
Lg wm3875h*ca water keeps coming in after it is shut off/ It takes about 4 days after I have washed before the water starts coming in. I checked the filters in the washing machine and changed out the...
If it is doing it with absolutely no power to the machine i.e. unplugged, then it still has to be a water valve letting water in and not closed/seated correctly. If it only happens when there is power supplied to the washer then it is likely to be the control board not feeding the correct voltage to whichever valve it is (turn either the hot or cold off at the tap/fawcet to determine which it is).
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 04, 2011 | LG WM3875H Washer
I am getting water in the drum. At first I thought it wasn't pumping the water out, but last night, I heard a continued beeping sound, and it was flashing "do" on the little screen and the...
Remove power completely AND turn of either the hot or cold tap/fawcet and see what happens. If no water being fed into drum turn the tap which is off back on and see. If water is being fed in again then it is symptomatic of a malfunctioning whichever water control valve not closing completely- its default/no power position. Sorry but it needs replacing.
If water is only being fed in when there is power on it could be the control board feeding the incorrect voltage to the valve ;-0(
John C
Sep 01, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
I have a Kenmore 2 speed automatic washer and the waterflow will not shut off, even when you shut the switch off. What could be the problem
This is symptomatic of a malfunctioning (not closing properly) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Check which one, if your's is hot and cold, by turning one of the taps(fawcets?) off and observing what happens.
Sorry but whichever it is needs replacing and a service call ;-0(
John C
Aug 26, 2011 | Washing Machines
Tub is filling with water, when the washer is not running.
This is symptomatic of a malfunctioning water control valve- the hot or cold water one if the washer is hot and cold fill, and the cold one if it is just cold fill!
If yours is hot and cold fill discover which one by turning one of the feed taps/fawcets off and if the water stops, it's that one!
Sorry but it needs replacing and a service call ;-0(
John C
Aug 15, 2011 | Whirlpool Washing Machines
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
Noisy water pipe
it is called hydraulic hammer nd meant that you have very good pressure in your lanes, if it start suddenly, this meant that your air chamber lost it's air, in that case simplest solution will be as follows:
1. close the mains,
2. open all taps (fawcets) and drain all water from the system,
3. close all taps (fawcets)
4. open mains and check if hammer is still present.
if hammer is still present, that meant you need to clean your airchamber, you need to find where it is lockated, follow steps 1 and 2, open airchamber, check if any debris inside and clean, re-seal the chamber, then follow steps 3 and 4.
if hammer was always, this meant that you do not even have airchamber. you can install one easy for yourself, just purchase one, and best place for it is on the end of the line, somehere close to most offending faucet.
if you find this advice helpfu, please do not hesitate leave your remark and give me your vote, thanx!
Jul 31, 2010 | American Standard Plumbing
Washing machine - not spinning, loud buzz
Sounds like your machine is not receiving any water. It could be that your tap (fawcet) is turned off, or there's a kink in the hose.
Nov 26, 2007 | Washing Machines
GE GSS25LGM Side by Side Refrigerator Logo
231 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
