Question about Refrigerators
Hello i have a problem with my no frost fridge. the ice blocks the fan in the upper section and it stops working.
  • Refrigerators Master
  • 8,220 Answers
Check your defrost system. Your heater is probably bad. Read more
Posted on Jan 08, 2009
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
Freezer cools well, refirgator is warm, the vent that brings air from frezer to refrigator has no air movement, ice inside , i broke some ice with knife shoul di spray hot water to get rid rest , I did...
This answer will be somewhat long, but in order to understand the "fix" for your problem you need to understand how a refrigerator-freezer works.
Most units have ONE COMPRESSOR which usually cools the FREEZER. Then, to cool the fridge area, there is a DUCT or ducts between the freezer and the fridge area to move some small amount of very cold freezer air into the fridge section. In the old days this occurred by convection, but most newer units have a small fan in the duct to more dependably move the air.
The run time of the compressor, and thus the temperature of the freezer is usually controlled by a THERMOSTAT [usually with numbers on the dial]. A second control [usually with the letters A, B, C, and sometimes even D] operates either a DAMPER in the duct, or controls the duration of fan operation in order to control the temperature in the fridge section.
Under certain conditions of higher humidity, FROST [fine ice crystals] can build up in the duct, and on the fan if there is one, reducing or totally blocking the cold air flow from the freezer to the fridge section.
From your description of the freezer working well, but the fridge section being "warm" suggests that blockage of the duct is what has happened. However, there are a couple of other possibilities:
1. You inadvertantly moved the fridge control to a warmer setting,
2. You inadvertantly placed something in the freezer and/or fridge which BLOCKED the entrance or exit of the duct,
IF one of the above are the cause, a "manual" defrost of a few hours with the freezer and fridge doors open to allow warmer air in should melt out any frost/ice from the duct and allow the system to work properly. Depending on the severity of the frost/ice buildup, it could take a couple of days to fully melt all the frost/ice.
During the manual defrost ALL frozen and perishable foods should be temporary stored in an ice chest or cooler of some kind.
One more thing, in addition to heavy humidity, frost/ice buildup can also be caused by a defective automatic DEFROST TIMER. IF the system does not do its regular defrost cycle [usually an hour or two once in each 24 hours], then frost/ice buildup can occur even with "normal" humidities.
So, once you have the system back in operation, watch for the normal cycling of the defrost program, and if the problem continues, contact a qualified refrigeration repair technician to repair or replace the defrost TIMER.
Jul 13, 2011 | Refrigerators
G.E. Bottom freezer evap drain keeps freezing up and ice build up stops fan so no cooling in fridge compartment. How can this be solved?
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 22, 2011 | Refrigerators
Cooling has stopped in the upper refrigerator section. Frezzer section ok. Indicator says 64 degrees (upper). I push the button for temp and it says 36... then reverts back 15 seconds later to 64
Since the freezer is working the duct can be blocked . So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | GE PFS22SISSS Stainless Steel French Door...
Recently got called out to an aeg electrolux s range.found evap drain pan in freezer to be iced up.the reported fault was fridge section too warm.found evap fan blade caught in ice, ducted air not getting...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Feb 26, 2010 | Refrigerators
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
My refrigerator is freezing inside the cooling section also there is water dripping inside the cooling section
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp and Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 10, 2009 | Refrigerators
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer works fine...refrigerator section
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
