Question about Technics SA-EX800 Receiver
Connecting MP3 to receiver
Can you connect a MP3 player to my receiver that is approximately 10 year old?
There are many products that will transmit to a standard radio receiver, here is one rather fancy example: http://www.the-gadgeteer.com/review/anydrive_car_mp3_fm_transmitter_review To find others which are much cheaper, search with mp3 and transmitter. But, make sure it will do what you want before you buy it!
Posted on Jun 01, 2007
I have a 3 year old sansa e280v2 that whenever plugged in to usb brigs up message "power surge on hub port". it will not charge.
Try connecting the Sansa to the computer directly, without going through a USB hub. The Sansa is not supposed to work if connected through a hub.
Aug 18, 2011 | SanDisk Sansa e250 MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
Make sure the player is fully charged.
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC.
Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary.
To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
My sandisk sansa clip 1gb wont turn on
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
No sound connecting mp3 player to receiver.
my mp3 player doest have any sound t all
Oct 27, 2009 | Onkyo HTR500 Receiver
My computer doesnt recognize the Player (Code 10) error
it should install try connecting it to another computer if it does it again try this:
1. turn on mp3
2. put it into hold :a lock should appearon the middle of the mp3's screen:
3. press the back button on the mp3 for about 10 seconds the screen should blink then connect it to your computer
i did this in mine and my computer recognized
hope it helps
Nov 11, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Screen frozen player will not do anything
Have you tried:
1) pressing and holding the reset button (little hole on the bottom right of the player" for 10 seconds?
2) removing the battery for 10 seconds?
3) connecting it to your PC with the battery removed?
4) connecting it to your PC and pressing the reset button for 10 seconds?
Jul 23, 2008 | Insignia NS-DV2G MP3 Player
Lyra rca mc4002a
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Feb 01, 2008 | RCA OPAL M4001 MP3 Player
MP3 connection to receiver
absolutely! any audio device using wires can. connect the RCA plugs into the back of the Technics "LINE IN" jacks...the MP3 end may be a 1/8" mini stereo plug (widely available complete cord)
May 30, 2007 | Technics SH-AC500D Receiver
80 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
