Question about Canon PIXMA MP160 All-In-One InkJet Printer
Replacing Printer Cartridges?
How do I remove the Printer cartridges from a pixma 160?
Push down on it & lift it out.
Posted on Jan 08, 2009
How to remove and insert catridge on right
Switch on printer, wait up to initialize, lift cartridge access door located at right side of the printer(check snap shot)wait till cartridges stayed at right side,gently push cartridge down wards to un lock, take out cartridge, replace desired cartridge..close the door & check display for ready mode...Note: Used cartridges & refilled cartridges may give error message to replace it.. If you are replacing with new one, printer will print align page to align cartridge.. For aligning the cartridge put printed paper in face down condition in scanner & scan it.. 5_25_2012_7_00_52_pm.jpg
May 25, 2012 | HP Officejet 4355 All-In-One InkJet...
Printing blank pages
Hi Wendy,
This is known issue with Canon printers. Try the steps below.
Instructions
    • 1
      Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    • 2
      Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
      • 3
        Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
      • 4
        Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
      • 5
        Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Regards,
    Suhail
    May 20, 2012 | Canon PIXMA iP1600 Printer
    When i want to print they show check ink u162
    Check the ink Cartridges see if they need replacing, if not then just remove the cartridges and re insert them all again see if the Printer will detect the cartridges properly again possible a cartidge may have gone lose
    Sep 26, 2011 | Canon PIXMA MX310 All-In-One Printer
    Printer error 5100 when i am first turning on my mg8120 to set it up!
    Hello and Welcome to FixYa!
    If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
    Actually the printer is not actually loading the cartridge and showing you the Error 5100
    To solve this error follow the given steps:-
    First of all turn off printer
    then remove both the cartridges from the printer.Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches. After it return the cartridges and turn on the printer.Error will be automatically remove
    If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
    For further help, you can take my valuable,professional help by taking my Service
    Thank you for using FixYa!
    Aug 09, 2011 | Canon Pixma MG8120 InkJet Printer
    What is the E 5 error
    This is a cartridge recognition error. this can happen after being refilled many times or the contacts on the front of the cartridge have become dirty. Try removing the cartridges, Turn the printer off by removing the power cable, clean the contacts on the front of the cartridges with alcohol wipes or boiling water, be sure to dry before replacing in the printer. Switch on the power and replace the cartridges.
    If this does not work unfortunately replacement cartridges are required.
    I hope this helps, if so please rate this answer below. Regards GM
    Apr 22, 2011 | Canon PIXMA MP210 InkJet Printer
    Error 5100 appears on lcd when turning it on. How do I fix?
    Try removing and reseating the ink cartridges. If that does not work try replacing the cartridges with genuine Canon ink cartridges. This should alleviate your issue as error 5100 is due to cartridge failure of some sort.
    Mar 01, 2011 | Canon PIXMA MP610 InkJet Printer
    Canon Pixma ip2000 Inkjet printer wont print black. Replacing cartridge did not fix the problem.
    Remove ink cartridges,then print head.
    Clean print head with dry cue tips.
    Apply strong suction over black print
    jets on print head.
    Replace print head and cartridges.
    It worked for me.
    Oct 17, 2009 | Canon PIXMA iP2000 InkJet Printer
    Replacing cartridges in canon pixma mx 310
    Go to this page:
    MX310 Support
    Click on the "Support & Service" tab. In the "Search Our Knowledgebase" block, type in replace ink and click "Search".
    There should be a link at #1 dealing with installing ink cartridges. Click on the link and it will show with pictures and animation how to remove and install them.
    Thanks for using Fixya.
    Mar 30, 2009 | Canon PIXMA MX310 All-In-One Printer
    Printer does not print colour
    Do a deep clean and consider replacing the cartridges with OEM
    Nov 16, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    23 people viewed this question
    old marine
    old marine
