Question about Lexmark T632 Laser Printer
I have smudges that appear horizontially in a repeating patter
I have three or four repeating horizontal smudges that appear on all printed material .
I just bought this printer refurbished for a private seller.
I replaced the toner and it does the same thing.
Could it be the drum or something else.
What should I look at next? Thanks
    Novelist:
  • 125 Answers
Hi fpugliese630:
1. Remove the paper tray and look inside the printer on the upper part and you see two rubber feed rollers, (they should be a white color) if they have toner on them that could be one of you problems,you would have to clean or replace them if they are worn.
2. you can run whats called a half test, print any document and while the document is printing open the front cover when you think that the paper is under the toner cartridge so the printer will stop. look at the printed page to see if the mark is there. If the mark is not there than you have a problem with the fuser assemble.
Note*
Make sure that the paper path is clean.
Posted on Jan 09, 2009
  • 65 Answers
Id also take a look at the charge rollers. the charge rollers can be easily replaced and located. drop the top front door down about half way. notice the grayish roller hanging from the arms. dont touch or clean this roller because it will cause it to stop working and cause smudging on your prints. if the roller is multi colored, orange-ish or has lots of toner on it then Id say its time to replace the charge roller.
Posted on Jan 17, 2009
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
Blue color appears pinkinsh/now stripes and smudging
Are you using third party ink? make sure your ink is xerox OEM. This will clogg up the inkjets and ruin the print head for ever, If you have always used the third party ink then you might want to get a new print head. . If you have used xerox ink then It sounds like the magenta reservoir has spilled over the cyan. This is caused by moving the printer and not waiting for the cool down procedure. Also you might want to change the print head wiper. If the print head wiper is over used it won't clean the print head properly and what that causes is for ink to build up and causes smudge. also make sure the drum maintance kit is still in good shape. (its the yellow roller on the right side of the printer. Well hopefully this helps .
Nov 20, 2009 | Xerox Phaser 8400 Laser Printer
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
Envelope printing smudges
have you thought of using avery envelope sticker sheets instead
http://www.averyproducts.com.au/avery/en_au/Products/Labels
you can also download templates to use in word to line up the printing to the stickers
May 31, 2017 | Brother Multi-Function Center MFC-240C...
HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
Horizontal streaks in printing
If its not the ink.then u probaly want to buy a new printer unless its expensive.have someone look at it
Mar 02, 2008 | Computers & Internet
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Lexmark T632 Laser Printer Logo
454 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
