Question about TruTech PLV16190 Television
Verticle and horizontal outstretch the scree
Verticle problem: Heads at the top and the ticker at the bottom of the screen are cut off. Also the horizontal is adjusted out too far. How do I bring it back in to the size of the screen?
  • rminns Jan 08, 2009
    This is a TruTech T2000-D
  • rminns Jan 12, 2009
    The only video adjustments on th the remote are the standard contrast / brightness / color video re-sizing. I wonder if and where the pot would be located inside for making the adj.
  • 73 Answers
The Video modes should take care of that, you should be able to adjust it from the remote.
Video size/mode/etc.
Posted on Jan 09, 2009
5 Suggested Answers
SOURCE: Screen resolution to big for plama screen 50
You need to first let me know what you are using for a source and then check the TV setting for the format and make sure it is on normal
Posted on Oct 26, 2008
  • 189 Answers
SOURCE: horizontal line across screen
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
Posted on Sep 12, 2009
Testimonial: "Thank you for your quick response.while this is not a LCD tv but a CRT tv it sounds like the same problem.I won't fix this old technology so thank you"
  • 1738 Answers
SOURCE: my tv screen is to big cutting off ticker and a
It is your company that you are getting your cable or satelite from.
Posted on Nov 20, 2009
  • 11361 Answers
SOURCE: size larger than tv. Heads are cut off
Look for 'ASPECT', 'WIDE', or 'ZOOM' on your remote.
Posted on Dec 20, 2009
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Phillips flat screen 27 inch screen cuts off top and bottom
horizontal over scan , one H.V. cap is out of tolerance in hoz deflection
Fair Cost to fix 75.00 could be a few leaky diodes to. in addition to the cap
Jun 30, 2009 | Philips 21PT4475 TV
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
Multi player screen displayed side by side, i want one top, one bottom
its not your ps3 its the game, just go to options on the main screen or on the multipllayer menu and go to screen layout and change it to verticle from horizontal
May 17, 2009 | Sony PlayStation 3 40GB System
Screen size
Nov 02, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen adjustments??
On the remote, if you use the right and left keys on the pad with the OK sign in the middle, it will adjust the screen to several sizes including Cinema, 16:9, 4:3, Zoom, etc. I, personally, use 16:9 because I, like you, need to see the ticker symbols at the bottom. I hope this helps.
Sep 17, 2008 | RCA HD56W58 56" TV
Stretched screen on my Sony KP-53XBR45
u use a 4:3 resolution, u need a 16:9 to see the picture, or put the display on automatic mode for the tv channels, this ting u can find in the setinngs of the tv
Oct 22, 2007 | Sony KP-53XBR45 53" Rear Projection...
TruTech PLV16190 Television Logo
88 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
