Question about Motorola Mobility RAZR V3
Key Pad screwed up.
Yeah i dropped my razr in a sink of water and it messed up for a while then i let it dry for a few days and it works now and the only thing that doesnt is the Keypad or the side volume and recorder and camera button. but today i was hitting all the buttons and one worked then it quit. Should i just give it time to dry or ditch it and get a new phone. When i push any buttons there is a click sound, and all the buttons light up.
  • 35 Answers
Sounds like you did as such as you could do. Sometimes the water has chemical or minerals that deposit in the electronics not to mention corrosion setting up and sometime water is trapped in tight places thru capilary action. You might try the hair dryer again. Try some electronics cleaner from radioshack. I would just buy a new one after all that.
Posted on Jun 01, 2007
    Problem Solver:
  • 9 Answers
Well what i can do if you want it is probably broken but if you tke the sim card out and put it in a jiffy bag and send it to me i will take a look ok ?!? i bet your thinking i sound a bit dodgy but im not i do this all year round for free ! anyways e-mail me on lilianj51@yahoo.com thankyou !
  • grant johnson Jun 01, 2007
    hi sorry it me again i meant the mobile not the sim card send the phone to me i dont need the charger ill give you my adress when you e-mail me on the e-mail adress i gave you thanks a lot hope it helps ! ...
SOURCE:
Use genuine battery
keep your phone on the heater for a few days .I had the same problem with my e65 but worse.it was in the washing machine and i found the phone soaking wet.so straight away i got a dry towel and wiped it and left it for a few days.3 days later it was working fine.
so why don't you try it ,it worked for me so hopefully it works for you
Dec 21, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Water entered into my motorola v3i and power off automatically when i switched on and press the key pad.nothing functioning give me a solution please
you need to dry this guy out...
pull the battery and leave out... that will minimize electronic damage... if at all possible.
Purchase a container of silica crystals at a nearby hobby/crafts supply store (used to dry flowers).
put the phone and the open container of silica into a ziploc bag and let it draw the moisture out of your phone.
let it be for a few days...
No guarantees, but it could get you back up again.
K
Jul 02, 2009 | Motorola Mobility RAZR V3i Cellular Phone
One key pad not working on LG Voyager
I don't know if this will work for sure but when that happened to be a few days ago my keys didn't work either but i took my Battery out and dried them both off for 2 minutes on warm and cold and cool if that doesnt work i don't know what to tell you
May 26, 2009 | LG VOYAGER VX10000 Cellular Phone
Two Problems: battery is drain fast & PC interface don't work, software
It sounds like the most common issue I see with cellular phones today, liquid damage, the handset needs to be dried out completely for there to be any chance of success, use gently dry moving air flowing over and around the phone for several hours and clean any place you see corrosion with 99.9% rubbing alcohol and a medium tooth brush and dry again for a good long time, this may solve your problem but it may also be too late, remember if your phone gets even one drop of water in it it can be totally destroyed! Cheers!
Mar 02, 2008 | Motorola Mobility RAZR V3
Keypad
well dirt under key pad or water ect would need t4 t5 star tools take it apart clean it well ok thx nick
Feb 06, 2008 | Motorola Mobility RAZR V3
My razr v3c speaker phone key turns on and off by itself
have the phone keypad flex file reflash in the phone.
Or take the phone and have the flexcable replaced
Nov 20, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Phone got wet
I would definately let it dry out fully. Take the battery out and take it apart as much as you can and place in front of a fan (probably overnight). If there was water in the phone when you plugged it in it could permanently damage the phone. Even though the outside is dry, there could still be some water inside. I once had a remote control in a swimming pool overnight and followed these instructions and it worked fine after a couple days of drying. Hope this helps!
Nov 06, 2007 | Motorola Mobility RAZR V3
Frozen key pad
I have the same problem. Was not dropped or water damage to my knowledge. Just the red button works. When I open it, though, it shows the asteriks key as being pressed which is under the #7 key. Any help would be greatly appeciated.
Sep 08, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Razr v3 cell
Is your phone been dropped? or in contact with liquid? Check our local service center if they could find any phgysical damage on the phone.
Aug 10, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Dropped in Water Razr V3r
ok take the circular malfuntioning pice from the key pad take out blow dry and then take out the nuclear rector funtioning log and do same with that
Mar 02, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
