Question about SanDisk Sansa Clip MP3 Player
No sound for FM radio mode
It was working fine last week, it's all charged. I can here my "voice" recordings, but when I put it on radio there is no sound. Tried different headset, so thats not it? help
  • 8,596 Answers
The radio is weak on this device - try different areas of the house, and see if you can get reception on one good station. I have heard that the Sansa e200 series had the radio function ruined by a firmware upgrade, but it wouldn't apply to the Sansa Clip. As a last resort, you can reset all of your settings within the player itself- the user manual will show you how to do this.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
No sound on AM/FM but Sirius is fine
I would look at the antenna connections ... you will need to remove the unit from the dash to get to the back of the radio. [Google removal of that specific radio for your vehicle]. You may be able to get your hand up under some dash boards to reach the back of radio?
The antenna conception is typically a round coax conductor that goes to a plug into the back of the radio.
Try moving the plug around while radio is on ... if you get signal pull out connector and clean contacts with rubbing alcohol. Test again and reinstall.
Hope this helps!
May 04, 2016 | 2012 Dodge Grand Caravan
WHY WONT IT RECORD OR REPLAY - THE MACHINE RECORDS TIME BUT THERE IS NO SOUND
try plugging in an external microphone, if that works and it records then the microphone element in your machine is bad or a wire has broken off of the microphone
Apr 13, 2015 | Philips Pocket Memo LFH9370 Handheld...
I would like yoknow what format do i need to download a video to my vl-567
Supports MP3 / AMV / WMA / WAV / JPG / TXT
----------------------------------------------------------------------------------------------------------------------------------------Model: VL-567k / VL577k
  • Built-in Memory: 4GB Flash Memory
  • Supported Formats: MP3, AMV, WMA, WAV, JPG, TXT
  • FM Tuner: Built In, Radio/Auto Scan/Store/Erase
  • Lyrics: Yes. Supports .lrc format.
  • Data Retention: 10 Years
  • Voice Recorder: 200 Hours with recording rate of 8khz
  • Voice Mode: Selected content repeat function (A-B mode)
  • Weight: 1.3 oz.
  • Dimensions: 3.6in x 1.6in x .34in
  • LCD: 1.8" Anti-Scratch True Color 65,000 color.
  • Equalizer: Natural, Rock, Pop, Classical, Soft, Jazz, DBB
  • Repeat Mode: Normal, Repeat Once, Repeat All, Repeat Folder, Random, Intro
  • Battery: Rechargeable battery, ~3-5 hours playing time when fully charged, ~10 hours charging time through USB port
  • File Transfer Speed: Reading (700 kb/s), Writing (400 kb/s)
  • SNR: 85db
  • Output Power: 5mW+5mW
  • Output Range of Frequency: 20Hz-20KHz
  • PC Interface: USB 2.0
  • System Requirements:
    • Windows 98SE/ME/2000/XP
    • 166 mhz cpu or faster
    • 32mb of RAM
    • 20mb available disk space
    • Available powered USB port
Dec 26, 2010 | Visual Land VL-567K Digital Media Player
Go gear will not operate in recording mode
The Go Gear SA52XX series is only capable of recording FM in Europe - the US versions, even though they have the same manual, will not allow FM Recording. I haven't heard that won't do voice recordings, but it doesn't surprise me - update the firmware - the directions are on Philips website. If it still won't record voice recordings, get a different mp3 player, because this is not the one.
The Philips SA6045, SA5125, and a few others will do FM and voice recordings. Ironically, the newer Philips GoGear's will not.
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
Fm radio and recorder modes
On this model, the Power button and the Menu buton are the same key - press the Menu button to go to the main menu, and it will display FM and Voice options.
Here is a link to the user manual:
http://www.sandisk.com/sansa/assets/English/products/c200/c200_userguide_en.pdf
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa c200 MP3 Player
Abt transcend tsonic840
Introduction
Combining a mirrored surface and metal body, Transcend’s MP840 catches people’s eyes. This new MP3 player is easy to carry because of its compact size (82mm long x 40.5mm wide x 12.5mm deep) and light weight (70g with battery). The 1.8-inch color TFT-LCD screen with high resolution (176 x 220 pixels), which delivers the best image quality, is especially designed for video and photo playback. The 3-phase wheel is easy to use and the brilliant graphic user interface displays clearly through the shiny screen.
As a portable multimedia center, the MP840 supports many audio and video formats such as MTV, JPG, BMP, MP3, WMA, WMA-DRM10, and WAV. This allows you to enjoy your favorite videos, music, or photos. In addition, you can read e-books with the MP840. It features a lyrics display, and is equipped with 7 equalizer effects that include a customizable USER EQ mode for you to create your own music style. With a fully charged battery, the MP840 supports up to 30 hours of continuous playback, so you can enjoy music all day.
The versatile MP840 is not just a portable entertainment center, but also provides many useful functions such as digital voice recorder, FM radio, FM recorder, real time clock to display world times, and has a 13-language interface. The language-learning feature, with adjustable playing speed and A-B repeat function, helps you learn foreign languages in an effective way. The built-in Hi-Speed USB 2.0 connector provides quick charging and data transferring. MP840 is now available in two capacities: 2GB (Glacier White) and 4GB (Mystery Black).
Features
- 1.8-inch (176 x 220 pixel) Super Color LCD Display for Playing Videos and Photos
- Plays Music, Video (.mtv) and Photos (.jpg, .bmp)
- MP3 Player supports MP3, WMA, WMA-DRM10 (subscription music) and WAV music formats
- FM Radio (FM Radio recording and the ability to preset 20 FM radio stations)
- Advanced Digital Voice Recorder
- Ability to read E-books (.txt)
- Karaoke-type lyrics display
- VAD (Voice Activation Detection), Very High quality Gapless Audio Recordings
- A-B repeat function allows you to continuously replay a designated section of a track
- Variable Track Playback speeds
- Supports 13 user languages including song/artist name display
(English, German, French, Japanese, Korean, Greek, Russian, Spanish, Italian, Portuguese, Turkish, Simple Chinese, Traditional Chinese)
- USB Flash Drive capabilities for data transfer and storage
- Included Software can be used to Lock your computer and setup Passwords for your files
- 7 Equalizer effects, including a customizable USER EQ setting
- Powered using a rechargeable Li-ion battery (fully charged battery supports over 30 hours of
continuous music operation) *
- Hi-Speed Mini USB 2.0 port for easy computer connectivity and fast file transfers
- Real Time Clock (RTC) displays local and world times
- Sleep Mode, preset the player to Auto-Power OFF after 15, 30, or 60 minutes
- Automatic screen saver runs if the unit is idle for more than a few seconds, this acts as a battery saving measure
hope this info helps u....
Dec 15, 2008 | Transcend T-Sonic 840 MP3 Player
Lost instruction
ok lamar230990 to turn your mp3 player to msc mode disconnect it from the computer and turn it on. once it is on go to settings and scroll down to protocol and click on it with the play/pause button. this should turn it to msc mode then connect back in to the computer and go to this site to download the software www.rcaaudiovideo.com
Oct 22, 2008 | RCA M4204 MP3 Player
I need 2 know how 2 uninstall info from my mp-4001 moV.ox centon
Do this procedure for "voice" mode to delete voice recordings:
Delete file (stop submenu) - Delete corresponding files and save files in Music mode, Voice mode or FM mode.
1. In stop interface (FM without stop interface)
2. Short press "MODE" to enter stop submenu
3. Click "NEXT" or "PREV" to choose "single" or "all" files
4. Short press "MODE" to enter the Delete interface
5. Click "NEXT" to change "no" into "yes"
6. Short press MODE to confirm the delete prompt
"Delete all" will delete all related files stored in the selected folder. For example, if in music mode "Delete all" will delete all the music files, while other recorded files (e.g. voice recordings or FM recordings) will not be deleted.
Likewise, if "Delete all" is used when in the "Replay" menu, this will delete all recorded files but leave music files intact.
FM is much simpler – "Delete" or "Delete all" will delete the station(s) saved before.
-Tha Mp3 Doctor
Jan 08, 2008 | Centon Electronics MP4-001 MP3 Player
Fm radio
Just press the A-B button on the top and it will switch to a screen where you can select the FM radio or the voice recording options. HTH!
Jun 13, 2007 | SanDisk SDMX1 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
230 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
