Question about OKI Microline 3410 Matrix Printer
OKI Microline 3410
How to install this priner of Windows XP SP2 ?
3 Suggested Answers
  • 32 Answers
SOURCE: Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Posted on Feb 15, 2008
  • 157 Answers
SOURCE: i have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Posted on Nov 09, 2009
NEED INSTRUCTIONS ON HOW TO CHANGE OUT A PRINTHEAD ON A OKIDATA 3410 PRINTER
Printhead
(1) Open the access over.
(2) Pull up and rotate the head clamp 1 to unclamp the printhead 2 as shown fig. 3.3.1.
(3) Disconnect the printhead 2 from PC connector 3.
(4) To install, follow the removal steps in the reverse order.
Notes on installation:
(1) Insert the printhead 2 into the PC connector 3 while pushing it against the carriage
frame 4.
(2) The head clamp 1 must surely be sandwiched between printhead 2 and carriage
frame 4 as shown Figure 3.3.2.
(3) Be sure to check the gap between platen and printhead (see 4).
(4) Be careful not to touch the print head while it is very hot.
(5) Make sure that there is not any dust or oil on the connector contact section A. If it
is found, wipe it off by alcohol. Good Luck ! I couldn't attach any pictures.
Dec 17, 2010 | OKI Microline 3410 Matrix Printer
I am using XP but I cannot install the driver for my refurbished oki ml420 - can you advise?
http://www.fixya.com/support/r4871388-installing_missing_drivers_free_charge
Made by me please rate it :)
May 21, 2010 | OKI MicroLine 420 Matrix Printer
Acer Aspire AS 3410, OS - WIN XP, shut down not work.
that means the drivers which you had installed is not working properly. u need to download the drivers of audio video & NIC card . check out the site. support.acer-euro.com/drivers/downloads.htm. make sure you have SP3 for XP.
Apr 12, 2010 | Acer Computers & Internet
Windows xp printer driver for Oki 320
Install an IBM Proprinter III driver. This driver is built into your Windows system and can be found in the Add Printer Wizard.
the computer will install that driver and it will make this unit compatible with windows xp
Oct 07, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Lost installation disk for microline 520 printer
Did you check on-line with OKI? If they do not have it, check used computer stores on-lne and ask if they have it. Perhaps they can burn you a disk for a small fee.
Does you new computer have it in their database?
Go to Printer install, and check the OKI database in MS windows. Might be there. Just install and go to work.
Cheers.
Mar 27, 2009 | OKI MICROLINE 520 Matrix Printer
Oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Oct 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer is going over each line twice
check your driver make sure the driver is the same on both printer and in windows .If you are using IBM make sure you use " IBM Proprinter" in windows.Hope this helps.
Dezzi
Jun 26, 2008 | OKI MICROLINE 3321 Matrix Printer
Page comes up blank !!!
check your rribbon.
also cjeck your head.
try to tast page from printer properties.
also try to print from dos .
check your printer datga cable.change it
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 320 Problem...
I think you maybe using the wrong driver.Printout the menu if you are set for IBM than choose the "IBM Proprinter" driver in windows.Hope this helps.
Dezzi
Feb 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 3410 Matrix Printer Logo
126 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
