In device manager under other device a question mark appears and under that multimedia audio controller is shown with exclamatory mark. When I double click the exclamatory mark, the window shows a message that the drivers for this device are not installed. Again I could not find the driver to install. Kindly suggest me.
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Hi, you are not hearing sounds from your computer right? In your Device Manager, it is indicated with yellow(!) because you have to install the audio driver. Post the Manufacturer and model name of your motherboard or sound card so I can give you the driver or link.
    *Drop me a comment so I can assist you.
  • 86 Answers
You nee to make sure the onboard sound is turned off and then you may need to reload your driver.
Posted on Jan 08, 2009
No sound from toshiba satellite t115_s1100, the motherboard is a toshiba satellite t110, i cannot play itunes, dvds ect. think it is a problem with sound card, can i fix manually? it is under warranty...
If its a driver issue then ofcourse you can do it yourself. Open device manager. Start-> Run type in devmgmt.msc and under sound video and game controllers see if any of the devices have a yellow exclamatory mark next to them. Also let me know whats your OS(XP, Vista, Windows 7?) so that I can get you the driver.
Oct 01, 2010 | Toshiba Computers & Internet
Tip
How to setup your Sound.
Install the drivers for the sound device. If the sound hardware came with an installation disc, insert the CD into the drive and follow the prompts. If the sound device does not have a disc, contact the manufacturer or download the drivers from the manufacturer's website. To check the system for sound devices, go to "Start," "Control Panel" and "Sound and Audio Devices." The primary sound device will be shown in the top of this window. Step 2 Check the "Audio Devices" properties window for muted volume or the volume bar set to minimum. Either of these will cause the sound to not work. Step 3 Check "Device Manager" for improper settings or problems with the device. Go to "Start," "Control Panel" and "System," then select the "Hardware" tab, then press the "Device Manager" button. A list of hardware will be displayed. Audio devices are under "Sound Video and Game Controllers." The device will be titled the same as it appeared in the "Sound and Audio Devices" window in the "Control Panel." By double clicking on the device, it will display the properties. There is a selection at the bottom of the first tab that will display whether the device is "Enabled" or "Disabled." Any conflicts will also be given in the form of small exclamation marks. Step 4 Check the volume knob on the physical speakers.
on Feb 21, 2010 | Computers & Internet
Control Panel says I have no audio device. Speakers are plugged in and have power.
No audio device implies that you do not have a driver installed for your soundcard/on-board sound. To verify this click start->Run and type in devmgmt.msc and hit enter. When the device manager opens click the + sign next to sound video and game controllers and see if there are yellow exclamatory marks next to any of the devices . Post back with what you found so that I can verify if its indeed a driver problem and then get you the driver.
Sai.
Oct 01, 2010 | Dell A215 Computer Speakers
No sound from PC, problem with multimedia audio controller
The yellow mark indicated the multimedia audio controller driver was not installed, therefore the audio won't work/no sounds.
You need to identify the make and model of the audio card and if you haven't the audio installation CD then you can download the driver from the manufacturer's WEB site.
Since the repairer fixed your computer, he should have installed the audio driver. I suggest you get the repairer to install the audio driver as it should have been part of the repair service.
Also if you see any other yellow marks against any devices in the DEVICE MANAGER then these will also need the drivers installed.
Apr 05, 2010 | Computers & Internet
My daughters laptop does not have any sound. It says "the audio service is not running"
I have afrontech jil7000sound card it couldnot be installed from the cd how to download from the site
Seems like there is no auto installation option in the cd.
If you have not tried the device manager installation way, try the following.
open control panel->system->hardware->device manager
then select the audio card name from the device list which is not installed or has an exclamatory icon next to the device not installed. double click it and a new window will open from that select
update driver-> no i don't want to go online-> i'll install driver my self->search in removable media(cdrom) then the driver will install automatically.
this way you can install.
Apr 22, 2009 | Computers & Internet
Multimedia audio controller
This indicates that the sound drivers are missing from your computer. You will have to identify the sound card that is installed on your computer before proceeding with downloading the correct driver. To identify the sound card, follow the steps below (Assuming that you are using Windows XP)
  1. Open Device Manager (Right-click My Computer>Properties>Hardware>Device Manager)
  2. The hardware whose drivers are missing will appear as Unknown device, so it’s easier to locate the device.
  3. Right click on the unknown device and click on Properties.
  4. Under the Properties window click on Details tab and select Device Instance Id from the drop down box.
  5. You should see a code similar to this
    PCI\VEN_8086&DEV_27DC&SUBSYS_30868086&REV_01\4&1E46F438&0&40F0
  6. The portion of the code highlighted in RED is the Vendor ID and the portion highlighted in GREEN is the Device ID. In this example:
    Vendor ID = 8086
    Device ID = 27DC
  7. Once you have obtained both the IDs, proceed to www.pcidatabase.com . There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID.
Mar 25, 2009 | Acer Computers & Internet
B 2131
Download the original notebook driver here
Before installing, extract the files from the archive that you downloaded to a temporary directory on your hard drive labeled “Drivers\ Audio.”
To install, please follow the instructions below:
  • Open Control Panel/System/Hardware/Device Manager.
  • Highlight the Multimedia Audio Controller under the Other Devices. Double click the device..
  • Go to the Driver tab and click on update driver.
  • Select Next
  • Search for a suitable driver and specify the location to c:\drivers\audio.
  • Select OK.
  • Windows will find the Multimedia Audio controller.
  • Select Next.
  • Continue with installation by selecting “Yes,” ignoring the digital signature message.
  • Finish installation and close the device manager window.
Dec 23, 2007 | Fujitsu LifeBook B2131 Notebook
Soundcard
Well you try this first. Right click on My computer, Select Properties, click on Hardware tab, click on device manager.
From the list double click on Sound media and game controllers..If you find an exclamatory mark next to the devices then if is a driver problem..Otherwise Its a hardware problem..Let me know what you found so that we can proceed further..
Oct 30, 2007 | Computers & Internet
No sond when ibought it from person
try this right-click on My computer->click Properties->Click Hardware tab->Device Manager->now double-click on sound video & game controllers and see if there are exclamatory marks next to any of the devices..If it is then let me know and i will help you to troubleshoot it..
Oct 21, 2007 | IBM ThinkPad 390X 2626 Notebook
Computers & Internet Logo
David Payne
David Payne
