Question about Kenmore 44102 Front Load Washer
Water leaking out the detergent dispenser
Everything seems to be open. I found no cloggs.
  • Anonymous Jan 10, 2009
    water leaking out of the dispensor also!!!
  • dlypooh Jan 11, 2009
    I have the same problem, and it looks like there is a slow drain leading into the washer from the dispenser. HELP!
I actually solved this problem. The water wasn't flowing into the machine, so there was a back up. We removed the rubber gasket around the washer door, and looked inside, and lo and behold, there was a sock jamming the water flow from the soap dispenser!
Now, it's working like a charm!! good luck to everyone else, and thanks for the advice!
Posted on Feb 20, 2009
  • 188 Answers
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly (re: dlypooh), open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Posted on Feb 19, 2009
So my boyfriend and i took the rubber hose out that was connected to the washer itself and lo and behold, my animal print panty was stuck in it!!! that's some powerful suction...now it works great!!! also didn't need the extended warranty thank goodness!
Posted on Jan 02, 2010
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
My whirlpool duet washer is leaking water from the detergent compartment. Looks like the water can't get through the hole under the detergent compartment before it gets to where clothes are How can I open...
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Detergent is left in dispensers and dishes are not clean.
make sure you are getting hot water to D/W might also try different soap
Oct 26, 2009 | Dishwashers
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Oct 17, 2009 | Whirlpool WFW8300SW
My whirlpool duet sport is leaking out of large amounts of water out of the detergent compartment. it seems as if the water will not travel into the machine. any ideas?
Jun 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Flip it not dispensing detergent
soap probably dried up and clogge the ports,always run clean warm water through the unit till the soap is cleaned out
Dec 02, 2008 | Bissell 52889 Flip-Ease All-in-One Vacuum...
Kenmore 44102 Front Load Washer Logo
111 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
