Question about Panasonic PT-43LC14 Television
On the screen it comes up several times saying bulb and light what does this mean?
    Novelist:
    Scholar:
  • 67 Answers
The warning means that your lamp is nearing the end of it's life and needs to be changed out for continued reliable operation. If you look inside of you owner's manual, then it should tell you what model lamp you need and how to change it.
Also, the people at Panasonic are very nice, and should be able to help you in purchasing a lamp.
I hope this helps you...
Posted on Jan 08, 2009
Warning light come on saying check running light> in a fiat punto 1.2 grande. what does this mean
Ive had the triangle warning light on with message saying check running lights,after spending about 2hrs today checking connections and bulbs it would appear that after changing tail light bulbs on both rear clusters and both stop and tail bulbs the problem has now gone
Jan 17, 2014 | Fiat Cars & Trucks
Hi there, 2001 s type jag, rear fogs not fully coming on....the bulb element glows but will not fully light...any ideas
Either poor grounding near the lights or a high-resistance connection in the power wiring to the lights. Possible bad control switch or loose fuse connection. Try removing the bulbs, then replacing them several times to clean the socket connections. If this helps, spray some WD-40 into both sockets and turn the bulbs several times. Hope this helps!
Oct 02, 2010 | 2001 Jaguar S-Type
No picture coming out
where is the red flashing light comming from is there a image or text saying what it means?
but to be hinest i belive that the bulb has finished and died
May 13, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have a Toshibal 50HM66 DLP TV. I purchased it about 4 yrs ago. It worked well for 4 months and the bulb popped, since then I've had to replace the bulb 3 times at a about $150 per bulb. The last bulb...
I have had the same problem and after several trips to the shop I realised it was caused by humidity. The shop was air conditioned so the problem never happens there. A dehumidifier or air conditioner "solved" the problem.
Dec 27, 2009 | Toshiba 50HM66 52" Television
LED light dont come on!!! Pioneer audio receiver VSX-9700s
Do you mean that the display that show the audio source or mode doesn't turn on? Try shining a bright flashlight at the display and see if you can read it. If you can, then the backlight light bulbs have died.
Replacing it will be a pain but you may find a usable replacement at Radio Shack. Just measure the voltage that goes to the bulbs and find one with similar ratings. They are probably 12v lamps.You will need to remove the display from the front panel of the amp and desolder the old lamps. Getting at the bulbs is the hardest part.
Dec 25, 2008 | Audio Players & Recorders
Tv Problem
check the circuit board for possible loose connection,try to resolder the horizontal circuit and the crt board.
Jul 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic PT-43LC14 Television Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
