Question about Freezers
Ice builds up kitchenaid superba icemaker kuis18nnjx4
Works fine sometimes but most of the time where the ice is made it keeps building up instead of sliding onto the cutting wires. once this happens i have to turn it off and let it thaw. this is a stand alone icemaker
  • Freezers Master
  • 3,463 Answers
Hi.
Sorry to have taken so long to respond to your post
Unfortunately I am not a refrigeration expert, so am not able to help you with your prob.
Find an expert on freezers, there are plenty to choose from.
Once again , sorry I cannot help you.
Posted on Jan 11, 2009
Long time not using the ice maker, today I tried an is making ice
I would replace the water filter first off. If you have completed that already then I would check the water fill outlet for calcium build up. If that is clear, check to make sure the solenoid is energizing for the fill. If you have water to the basin and it is still not working I would have to check the timer to see if it is initiating a cycle for the ice.
Apr 08, 2014 | KitchenAid 18.5 cu. ft. Bottom Freezer...
Countertop Icemaker is only making a few thin cubes every hour , maybe buildup from bad water ! What can i pour in it to clean ?
I would switch off the power, disconnect water and keep it so for a few hours. While power off, clean whatever visible build up you find. And make sure you shut the water valve before disconnecting unless you want another project! After a few hours connect water and power and wait until ice made. Goodluck.
Apr 05, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Our freezer is not de-frosting, there is a build up of ice
Sometimes ice will build up because of hummity. dont know where your at but best thing would be to get everything out and turn off . and defrost manually we used to do this on old friges with a hairdryer. it takes a while. when you start it back up make sure the seal seals good and if ice builds up again the your going to get to call repair man. Hvac and all compressors go through defrost mode. You may have so much ice it wont defrost, also a full freezer works more effecient than empty.
Feb 26, 2011 | Freezers
Only 6 months, have to defrost.
However this will take long so you use a straight screwdriver or something like a chisel to remove as much scale as possible before leave it in solutions.
The ice build up is related from the time keep the door open and the humidity that is in the air. So the time is variable. Sometimes if the door is not sealed closed the ice is build up very fast.
Nov 01, 2010 | GE 14.8 cu. ft. General Electric Chest...
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
There is an almost constant clicking sound from the back of the unit. When the door is opened the clicking stops temporarily and then recommences. The icemaker is not working either and when water is...
Your evaporator fan is hitting ice build up, reach in and see if you have ice build up on the wall. If so you have a defrost problem other wise if its freezing good the is just a small amount on the frame just high enough to touch blades as the go around. You might try a hair dryer around thhe fan.
Apr 21, 2010 | Freezers
My subzero 601 F freezer door gets hard to open unless you wait 4 minutes. While investigating this I discovered that there is a buildup of ice in the trough behind the icemaker. It appears that the drain...
switch off machine. open doors an manually defrost.clean any filters/drain holes(wire is not heated,pull/push to clean pipe)dry as best you can.switch on again.it is best to manually defrost any unit every 6 months and if temp edjustable adjust to -20c for optimum economy.water to icemaker is not important on 601f but is on some others.be carefull
Feb 06, 2010 | Freezers
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
Freezers Logo
83 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
