Question about Harman Kardon HK 3480 Receiver
Harmon/Kardon 3480 When trying to hook up our receiver to outside speakers, the receiver states "protect" and shuts off. This happens as soon as the power is turned on to the receiver. What did we do? What can we try???
  • Beth McFarland Jun 01, 2007
    The speakers aren't hooked up right now, but it is still doing the same thing. We are trying to reset, but it won't work. Can we try something else?
  • 934 Answers
Beth, Protect mode in this unit indicates an open or short problem in one or more of the primary amp IC's in this unit. For a qualified shop this is a bit of a challenge sometimes disasembling the unit to put the amps in... The amps sit on a large aluminum heatsink and and each have their own set of feed resistors and caps. Each amp found to have failed should have their compliment of resistors and caps tested in orfer to prevent premature failure of the new amp(s)... If you're looking for a repair shop to do the job find someone who specializes in stereo receivers and amplifiers. If you're not sure where to begin you might call NESDA (National Electronic Service Dealer's Assn.). They can direct you to a member shop in your area... Hope this helps, Good Luck! Bill
Posted on Jun 04, 2007
Not getting any sound out of speakers help please :(
You need to set the device on the aux mode. Connect the cable at aux. Sign at the back of the device
good luck
May 07, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
Where to buy transistor for hk3480 part num 328 kca3114
Are you sure that is the part number? The HK-3480 uses a KTC3114A and is quite easy to find. Q317 and Q318 in your receiver.
Make sure you see the numbers correctly.
Jan 16, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
Harmon Kardon Receiver "Protect" Mode issue
If your receiver enters protect mode with no speakers connected, it is an indication that you will have to start troubleshooting inside.This will involve visual checking and checking with a multimeter to isolate the problem. A further issue is finding out why your JBL woofer keeps blowing fuses. It could be shorted.
Dec 12, 2013 | Audio Players & Recorders
How to troubleshooting
prob with the audio amph on the motherboard
Dec 04, 2013 | Harmon Kardon Harman Kardon Harman/kardon...
When i turn on my harmon kardon avr 165 it shows ''Protect'' and then it turns off again?? what can i do :)
I would try disconnecting the speakers, then turn it on. If protect still shows with no speakers connected, then it needs to go to the repair shop- Might be a blown power transistor.
Oct 24, 2013 | Harmon Kardon Harman / Kardon AVR 165...
Harmon kardon hk3270 shuts off after only being on about 10 sec
Disconnect speakers and wires. Bad wiring or defective speakers may be loading the amp down and causing the protection circuits inside to disconnect (no sound). If the HK is heating up (beyond what you perceive as normal) with no wires or speakers connected then you have a problem requiring expert repair.
Oct 31, 2012 | Harmon Kardon Harman Kardon HK 3270 65W/CH...
Reciver goes into protect mode as soon as I turn it on.
Remove speaker wires and try again. If it still goes into protect mode, the problem is internal...shorted power transistors or some other fault. Check fuses also.
Apr 01, 2010 | Harman Kardon HK 3480 Receiver
Why does my harmon kardon reciever keep protecting when i turn it on? i checked the fuses.... nothing wrong...?!?
Check the speaker wires.
Make sure your ohm loads are stable especially if you are using more than one pair of speakers to any output.
Check the starting volume.
Nov 23, 2009 | Harman Kardon HK 3480 Receiver
Protect mode
have you ever been able to hear anything from this unit?
Jun 04, 2007 | Harman Kardon HK 3480 Receiver
Harman Kardon HK 3480 Receiver Logo
378 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
