Question about Maytag MGR6772 Gemini Gas Kitchen Range
Oven igniter problem
I have a 1993 RCA gas range Model #LGB356GET2WH. The 4 top burners work fine and the burner for the broiler works fine, but when you turn it on bake the burner doesn't come on. No sound, no gas smell. The problem just started a few days ago. It didn't work, then the next day I tried and it did work, and now 2 days in a row nothing. Any idea what the problem is? Do they still make parts for this and is it worth fixing?
  • Anonymous Apr 22, 2009
    Same thing here, any help?
  • 375 Answers
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Amperage should be 2.5-3A. If less than 2.5A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers : WB2X9154, 4342528, SGR403, 5304401265;
Those ignitors are interchangeable, if you can splice the wires. If not comfortable splicing wires - replace it with the first one in the list, should be direct replacement.
Posted on Jul 15, 2010
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Dec 06, 2007 | Kitchen Ranges
Oven not working, but broiler is...
Very well could be. I'm assuming the bake burner is the problem, right? Does the igniter glow at all? If it is glowing, but the burner does not light, is it usually a symptom of an igniter that has become weak. If it does not draw enough current the gas valve will not open and the burner will not light. This is a safety feature to prevent free flowing gas without ignition. If the broil burner is functioning properly, then more than likely the gas valve and regulator are working fine. In most ranges both burners are fed from the same source. You could try swapping igniters between the broil and bake burners to prove the theory. Or, you could just replace the igniter all together. Current readings are as follows: Round shaped glow igniter: 2.7 to 3.2 amps Square shaped glow igniter: 3.2 to 3.7 amps If you can give me the exact model number off your range (usually located around the oven door or on the back of the range) I can give you the correct part number you will need. Most appliance repair stores carry the igniter. I hope this helps you.
Sep 14, 2007 | KitchenAid KGST307 Gas Kitchen Range
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
468 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
