Electric trips when switch on switch on socket
When i plug my washine machine into a electic socket and switch the socket on it tripps the electric?
  • Washing Mach... Master
  • 3,463 Answers
There is obviously an electrical problem that is causing the trip to operate try it in another socket, then check the plug , if o/k, then it is a case of open ing the washer up to try and locate the prob,
At this stage, it literally could be anything, from a faulty motor, faulty heater, faulty suppressor, the list is endless.
Plz rate my comments.
Thanks.
Posted on Jan 09, 2009
Look at any uninsulated or exposed wire, beside look at the seal (in this case water seal, somekind of rubber that prevent the water from leaking then flowing into live wire connection)...if the wire is broken, due to the mouse bite (normally this is the couse), you can tape it or insulated it with 'black tape', but make sure the suppy is unconnected and the power is off. an if the seal is broken, you may need help from services company to repair it.
Posted on May 15, 2009
Why would my malber WD 1000 keep tripping the breaker during drying cycle
breaker tripping is caused by an overload ( amps x voltage = watts). If the breaker is- for example -10 amperes and the voltage is 120 volts it equals 1,200 watts of power consumption and if the device is pulling more than the 10 amps setting of the breaker then, it will tripp. Just check how many amps is used by the device and if it is hooked to an electrical outlet that has a lower amps rating than the device then, it will tripp. Look for another electrical outlet that will support the device amps usage and give it a try to find if it does not tripp. If it still does then you may need to take it to a rapair facility to verify if there is any short within the device
Sep 20, 2015 | Malber Washing Machines
Why when plugged in to my electrical sockets it keeps tripping out my electrics.
Either Faulty , or the unit power is to much for the electic cable / system. Always when power trips out , it's to do with the unit you have plugged in, (ie ) If it's a 3 kilowatt fire, this will trip unit as unit very sensitive
Mar 07, 2015 | Heating & Cooling
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Dishwasher blows breaker just sitting there off.
Are you sure the unit is off ?
If you have unplugged the unit and no breaker tripping occurs and tripps when machine is plugged in but switched off chances are you plug socket(on the wall) is the culpret here in which case I suggest you get a qualified electrician out to have a look.
Jan 22, 2009 | Dishwashers
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
