Question about Tissot T-Touch T33159851 Wrist Watch
Analogue hands don't correspode to digital clock
The watch went hay wire one day. hands kept rotating continuously then they stopped after a day. and everything has returned to normal except the hands do not correspond with the digital display. They are 2 hours behind. and now also when you touch the screen the hands rotate to about about 2 hours behind where they should be pointing.
Is their anyway to resync the hands withe digital display
  • bkirn Jan 27, 2009
    The digital time and the analog time are not synchronized.
    Moreover, when the minute hand is on 12 o'clock, the hour hand is between hours, as if it where approximately half past the hour.
    HELP!
  • Elliot Nov 04, 2012
    Thanks worked like a charm
    Sniper:
  • 87 Answers
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Posted on Jan 10, 2009
  • TJenna Sep 25, 2011
    Here is the link . . .to the User Manual. Page 6 of 13
    http://support.tissot.ch/usersmanual/141...
  • 2,071 Answers
Reset it again touch the screen to set ,when you going touch the screen the hands rotate,then wait to reach the hour you desired when it come touch screen again to stop and lock the setting.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 08, 2009
Yeah..thank you very much
i was so afraid i'm gonna screw my T-touch
You're the best !!!
Posted on Jan 18, 2009
Hi, I have a police watch 10962j and I thought the battery had expired due to the hands stopping. It was changed by a local timpsons however the clock does not work but the stopwatch facility does!!..is...
If the stopwatch facility is a digital LCD display, then you probably have a watch with TWO batteries. One for the electronics and one for the analogue hands movement. The Electronics circuit board can be lifted out, revealing the smaller hands battery.
Jan 30, 2018 | Police Watches
How do i set the date on the diesel dz-1216
two possible methods
1/ pull crown out to first stop rotate clockwise for date and anti clock wise for day.
2/ pull crown out fully to start moving hands rotate hands through twelve O'clock twice for each day to move when at the correct day set the time then pull crown out to first stop to adjust the date, push crown in fully when done.
Mar 03, 2015 | Diesel Strap DZ1216 WW Watch for Men
Unlisted Kenneth cole ul 1069 all other functions work except hands they stopped when trying to set date. what do I do to get hands working again?
your watch has two battery.
one battery for Digital
other one for Analogue
perhaps battery for analogue died
you need to change one battery
Sep 24, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Digital working, hands don't
digital and analogue watches have 2 different batteries,I believe you need to replace the battery of the analog part ..just reminder,so save money and time you can replace both at the same time to prevent to replace the digital one 2 months later.!
Hope this helps!
Take care and please Remember to rate/vote for us to continue for Helping out the Community :)
Thanks
Jul 04, 2011 | Watches
Day and date out of sync with time
Try rotating the analogue hand 12 hours ahead of the current time
Jun 19, 2009 | Caravell Bulova Caravelle watch
ADJUSTING ANALOGUE CLOCK
Keep pressing 'select mode' button until you get to H-SET. Than hold 'adjust' button until screen starts to blink. Now you can adjust analog clock by pressing 'start/stop (search)' button. When you are finished, just press 'adjust' button once. That's all.
Feb 18, 2009 | Casio AQ163WG 1BV Casual Sports Watch with...
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Tissot T-Touch T33159851 Wrist Watch Logo
1,598 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
