Question about Acer Aspire 5315 Notebook
Laptop does not shutdown it hangs while shutdowning what is solution why does it happen
  • 1,472 Answers
Dear dsn_123
In regards to your issue with your computer not shutting down most likely there is an application on the system that is not getting closed out properly that is causing the the system to hang at shut down.
You might try going into the task manager (you can access it by press CTRL-ALT-DEL). Once in the task manager make sure that all application are close out. Also your might check the processes to see if any are taking alot of resources. If there is this is most likely the problem. After ending task on it the computer should shut down fine.
If you still have trouble it is possible that you may have to coruption in Windows. If this is the case you may need to look in backing up your personal data and then reinstalling Windows on you computer.
Let me know if you have any more problems or questions.
Issken
Posted on Jan 08, 2009
    Brigadier General:
  • 8,619 Answers
Hi
You need to remove the battery and then place it back , it will surely work .
You can also download easy shutdown from this link
http://www.tucows.com/preview/337660
Thanks
Rylee
Laptop doesnt shut down
With xp you a have to select
Start --> the right arrow --> then shutdown.
Aug 27, 2012 | HEWLETT-PACKARD HP ProBook 4420S NoteBook...
Dell e1505 won't power off
Check or Change the PSU or charger.
Jun 28, 2012 | Computers & Internet
At the time of shutdown hang
You may have to many programs on startup, uninstall software that is no longer needed, do a disc cleanup and defrag the hard drive, this should improve computer performance and help with the shutdown process.
Jun 19, 2012 | Dell Vostro 1014 Notebook
Toshiba satellite A665-S6086 continuously hangs on shutdown and the only way to stop it is to hold down the power button or remove the battery. Running Win 7 with wifi on. If I use safe mode both without...
When I see this the first thing I try is start up repair in windows. This is usually an indication of a corrupted driver or bad ACPI driver which controls the shutdown function through power management. Doing a start Up repair and in some cases a Driver reload you can repair this.
Sep 15, 2011 | Toshiba Satellite A665-S6086 Laptop
Laptop gives no response after reboot/restart
how old is the laptop
if it has a disc hard drive it could be that the motor in the hard drive is failing
go into device manager and do a systems check
Apr 03, 2017 | Toshiba Computers & Internet
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
My laptop is stuck on "Logging Off".
You can hold down the power button until the system powers off, this will do a hard shutdown of the laptop. It will boot back up fine, but if this keeps happening then you need to look into what is causing the hang up.
Jan 12, 2010 | Computers & Internet
My Laptop hangs during shutdown
Speed up your computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Jul 04, 2009 | Acer Aspire 5315 Notebook
Can't type on HP mini 1035 NR. Cursor and enter are fine.
Try to forcely shutdown your machine. Hold the power button 5sec to shut it down, then boot up machine normally.
This happen sometimes when some of the application you are using hang up.
Jun 03, 2009 | HP Mini 1035NR Notebook
Restart problem
There might be possibility of Virus.Please check for virus.
This problem may occur if all the following conditions are true:
  • You have East Asian Language support installed on your Windows XP-based computer and the Input Method Editor (IME) selected as your default input language.
  • You have the Welcome screen turned on.
Check weather you are using service pack 1 or above.
If still problem occur then just try to download Shutdown patch from website
Apr 08, 2009 | IBM ThinkPad R32 2658 Notebook
Acer Aspire 5315 Notebook Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
