Question about Apple iPhone 3G Black Smartphone
Phone won't ring in sleep mode
While the phone is on and the screen is on, the phone will ring for an incoming call, however if it goes to sleep, the screen turns off, the phone will not ring. When i go to use the phone it rings as if the call is coming in but the incoming call was 2 hours ago. I have exactly the same problem. As soon as i put my iphone into sleep mode (by clicking on the upper right button), i do not get any incoming calls anymore. Hours later i get the SMS telling me there was a call...
Very strange!
  • 1 more comment
  • valy007 Jan 09, 2009
    Thanks a lot bdouglas :)
    I will definitely try this, but i have found out something new ... It's getting more weird.... I have disabled my 3G (in the network settings) and the phone works now perfectly... I hope your solution will work WITH 3G enabled
    I'll keep you up to date
  • GCD17 May 11, 2010
    I'm having the same issue & I've called Apple 3 times, done multiple restores, etc. & can't get it fixed. I've tried your solution, but I must be doing something wrong. Can you be more specific? 1. Do I just power off normally or hold down on both buttons while it powers off? 2. To power on, do I hold down on both buttons from the beginning? 3. Is the 10 & 30 seconds from the initial push of the button or 10 & 30 seconds after it completely starts up? 4. When it goes into DFU mode, will it indicate that to you? Again, I tried all these combinations & could not get it into that mode. If it didn't tell me, I plugged it in anyway & it did nothing but synch normally. Would appreciate the info. Thanks!
  • 290 Answers
I had the same problem with my iPhone the only way I was able to fix it was to re-flashed the latest 2.2 firmware. Power phone off, power on by holding power and home at same time, hold power for ten seconds and then release still holding home key for another 30 seconds to put phone in DFU mode. Then plug into iTunes it will detect phone in recovery mode and allow you to re-image
Posted on Jan 08, 2009
  • William Douglas
    William Douglas Jan 09, 2009
    It should as I never turned off the 3G on mine
  • William Douglas
    Sounds good
Incoming calls
I would try removing the cover of your phone and then remove the battery for about 10 seconds or so. This acts as a reset without removing information and apps that you have downloaded onto your phone. This should fix the glitch.
Oct 02, 2016 | Cell Phones
How do I fix my lg Optimus l-70 smart phone, it won't stop turning off and on and it won't stop vibering
Do you mean the screen turns off? Or the whole phone? If it's just the screen, that can be changed. Go to settings, then display, then sleep. You can adjust time you want it to wait until screen goes to sleep. I have mine on 5 minutes. Seems to be ok. Then to turn your phone back on from sleep mode, you just hit the on off button briefly, and screen comes back to life.
To fix vibrating, go settings, then sound, then UNCLICK 'vibrate when ringing'. Once you unclick that box, phone will just ring, but without vibrating.
Hope this helps!
Jun 18, 2015 | LG P705 Optimus - Black
Why don't my phone ring on incoming calls
Swipe up on your control panel from the Home Screen and make sure Do Not Disturb and Airplane mode are not ON.
Sep 24, 2014 | Apple iPhone 5S
Phones do not ring with incoming calls
Check make sure ringer is turned up,push speaker button then push volume button a volume thing should show up on the screen,keep pushing volume button and it will. Increase the volume.ty.
Feb 15, 2014 | Panasonic KX-TG2632 Twin Cordless Phone
My phone rings once and shows "Incoming call" on the LCD screen and when I answer, no one is there. People calling say the phone only rings once or it goes directly to voice mail.
You have to go into the menu and reset the rings so that the phone will ring at least 4 times. Your owners manual should give you directions to do that. You can also call Panasonic.
Aug 29, 2011 | Panasonic KX TG4023 Cordless Phone
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
LG Rumor2 Phone will not ring. It goes to voice t...
menu- tools- voice control-voice guide- alert off
May 21, 2010 | LG RUMOR Cellular Phone
LG KM900 Screen goes black when it rings and can not answer calls. No buttons wil respond and it just locks up whilst the incoming ringing happens. Answer mode is also missing from the "Common Settings".
If you have a screen protector on, the proximity sensor is covered by the screen protector. The sensor is locate on top left of the screen next to the inner camera. Cut of the piece of screen protector and it should solve the problem.
Jan 01, 2010 | LG KM900 Arena Cell Phone
Our phone does not ring with incoming calls,but call goes to the answering machine
Some of these contraptions have a setting in the menu where all incoming calls will be routed to the answering machine or after so many rings the answering machine will turn on.  Find the setting and turn it off.
Nov 05, 2009 | Audio Players & Recorders
Apple iPhone 3G Black  Smartphone Logo
547 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
