Question about Sylvania 6313CB 13 in. TV/VCR Combo
Tape stuck and tv turns off
I have an important tape stuck in the VCR. When I turn on the TV it says it's ejecting the tape but nothing happens. After about 5 seconds the TV turns itself off. Is there any way to get the tape out without ruining it? I don't care about the TV or the VCR.
  • 1 more comment
  • sistrpam Dec 12, 2007
    I have a Symphonic tv with vhs tape deck built in and a tape is stuck inside it shows eject on the screen when I turn the tv on then the tv shuts off I keep turning it on and hitting eject but can't get the tape out I want to keep the tape in working shape as it is a very hard to get old one I will try to open up the back and see if I can get it out if not I will take it to a repair shop and let them break the tv to get the tape out in whole for me .
  • Anonymous Dec 20, 2008
    I have a Sylvania 13 inch color tv/vcr.
  • Anonymous Mar 22, 2014
    opened the vcr...the tape is not stuct
  • 934 Answers
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Posted on Jun 04, 2007
  • Trudie S Mar 19, 2013
    Thank you!! You are awesome and THE MAN. Successfully removed my tape and put all back together. Great instructions!!!
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
Funai tv/vcr combo has a tape stuck
It shuts off due to an error or mechanical problem, this is a safety feature. Sounds like the gears are worn/stripped and needs to be serviced/replaced. The tape can be remove by opening the unit and manually ejecting it if its important to you.
Aug 06, 2009 | Funai F3819D Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Feb 16, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Vcr trouble
this combo unit as far as i know has only one power source which is in the vcr unit. if the vcr has a problem it affects the tv likewise. i beleive u did removed the tape, but unfortunately you misaligned the mechanism of the vcr which will in turn sense an error causing the automatic shuts off of the vcr and likewise the tv. u need to bring it to a qualified service technician if u dont know anything about this.
Jan 05, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Sylvania 6313CB 13 in. TV/VCR Combo Logo
526 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
