Question about Stanley Pneu Roof Stapler
I have a stanley Air gun that is leaking air. Is there an easy fix?
    New Friend:
  • 40 Answers
If you have the owner's manual, it should contain a parts diagram - it will usually give you the part number for O-Ring replacement kits, and if you can follow the parts diagram, carefully disassemble the tool in accordance with the parts diagram and replace each O-Ring one-at a time (so you don't forget which one goes where) and then carefully re-assemble in accordance with the parts diagram. Be sure to follow any lubrication instructions you may see in the manual or kit instructions. You can get parts and manuals from their website: www.bostitch.com
Posted on Mar 13, 2009
  • 2,176 Answers
It depends, what is the model number for this tool. They make rebuild kits that are not hard to install. If it is a trigger leak then yes that is easy. Let me know and I will try and help
Posted on Jan 08, 2009
Bostitch just blows air when trigger is pulled
Air leaking from trigger when attempting to fire the gun is normal and should cause nailer to fire, however if the trigger pin is not depressed all the way in,the gun may not respond. Easy test. Remove the nails and remove the trigger. Connect the gun to air and quickly depress the valve pin all the way in with finger. If the gun fires, adjust the safety foot so that the trigger pin is depressed all the way in. If the gun still does not fire, then remove the head cap and pull out the headvalve. Apply plenty of white grease to orings and retest. If the gun fires, then replace the headvalve orings. When the headvalve orings are worn, air will leak from bulkhead chamber to the headvalve chamber causing the gun to not respond to the trigger. The addition of grease to worn orings will make them temporarily seal. Good luck
Jun 16, 2016 | Stanley Bostitch N66c1 114"to 212" Coil...
Air leaks through cap vent
I had the exact same problem after doing a complete rebuild. If you are using the Stanley bostitch rebuild kit, check to see if you accidently swapped o-rings 6 and 63. They look the same but o-ring #6 is 1.925x.103 and o-ring #63 is 1.862x.103. Use plenty of lubricant. Hope this helps.
Apr 07, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Trigger is leaking air and trigger is not working on a bostitch coil nail gun
replace trigger valve assembly aka tva 6 you can get aftermarket ones fairly cheap that are just as good. it is fairly easy to do, usually takes about 10-15 min, lots of how to on you tube look under bostitch rn46 trigger
Oct 31, 2013 | Stanley Bostitch Rn461 Gun Coil Roofing...
Trigger leaking air and trigger does not work
Try adding some transmission fluid to the air inlet. Just a little squirt in the air nipple. Try the gun, if it doesn't work it may need a new o-ring kit. they are relatively easy to replace. Also make sure the allen head screws are tight. These hold the body of the piston assembly against the seals. If air is leaking from this area the gun will not shoot. The seal rebuild kit comes with installation instructions.
Oct 31, 2013 | Stanley Factory Reconditioned Bostitch...
I have a N59 FN air is leaking from the bottom of gun I put ne trigger and O rings still leaking now what.
Air leaking from the bottom of the gun (path of driver) indicates that cylinder seal orings are leaking (if without nails in gun the driver is slowly pushed down the cylinder when air is connected then cylinder seal is leaking ). Cylinder seal snaps on the top of the cylinder and should fit snug and have no cracks. Easy fix for cylinder ring. Remove head and pull out cylinder. Then remove the cylinder ring (part #n50015). Examine ring for cracks and replace as needed. Examine body of gun where spacer oring makes contact and sand fine scratches. Replace orings as needed. If air is leaking between body of the gun and nose casting, replace gaskets. Good luck.
Jun 25, 2012 | Stanley Bostitch Nail Gun
N12 nailer doesn't retract completly,changed all orings,trigger valve,cylinder/piston looks good and lubricated, whats wrong?
For nailer to retract properly the lower bumper should not be missing any pieces or cracked. The upper bumper should be pliable and complete. Pull the cylinder and check for a groove cut into cylinder with a series of holes. This groove should have a snug fitting oring. It should not take much force to move the piston within cylinder. If all seems good, re-assemble using silicone paste lube available at Lowes or swimming pool supply. Easy test. With air connected and nails removed, dry fire gun against coiled rubber hose. Keep holding the trigger and keep the gun against hose. The piston should stay down and no air should leak from gun while holding in this position. Lift up gun and the piston should retract. If air leaks from bottom while holding in this manner, lower bumper is not sealing, if air leaks from top, then upper bumper is allowing air to leak from head valve. Good luck
Feb 17, 2011 | Stanley Air Tools & Compressors
How to fix a bostich roofing nail gun that leaks air from top of gun
You need a refit kit to suit that gun which comes with new gaskets to prevent air leaks.
Apr 02, 2010 | Stanley Air Tools & Compressors
Stanley finsish nailer and air is leaking through the trigger as.
If the air is coming out the trigger it must be replaced. Depending on the model of gun you will have to replace the trigger assembly or various o-Rings. Find a Bostitch dealer in your area and they will supply the parts you require.
Jul 14, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Air leak on framing gun
You can repair this gun. Parts and breakdown are at www.bostitch.com look for service /parts and enter your model number. There you will the parts available for purchase. You will need the tva11 trigger valve. Easy to install. Remove roll pins that hold trigger and trigger valve. Remove the trigger to expose the tva11 valve. With the roll pin/s removed that hold the trigger valve you will be connecting air supply. Use heavy glove to catch valve as you apply air pressure. You may reduce pressure to airline to reduce pop-out force. Before you install the new valve check port for sharp edges and debris. Good luck with your repair.
Mar 16, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Stanley Pneu Roof Stapler Logo
152 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
