Question about IBM ThinkPad R51 Notebook
My Ibm T22 wont boot up
My daughter used the laptop & the battery went flat so instead of putting it back on the charger she put it away , Then I come along & started it up it opened to the Windows XP black start up screen & then the alarm sounded that the battery was low & required alternative power hook up & shut down before I could plug it in.
So I put it on the charger the battery is now fully charged but will not power up at all when you presss the power button t5he battery light flickers for a split second & that is all it does
Could it be the backup battery is stuffed ????
Greg from Wagga Wagga. Australia
  • greg_bickley Jan 08, 2009
    ok guys it just decided to start up after trying 40 times or more & it entered in to bios setup I set the date & time & set the default setting saved & exited & it started as if nothing was wrong so I guess the back up battery was flat & required time to charge enough to start up the machine
    Thanks guys for the time to help me out
    Greg Bickley / Wagga Wagga. Australia
What its doing ive experenced 2 ways. First is overheating. If it powers off because of overheating you can pull the main battery and let it sit and it will come back on. If that doesnt work it could be the motherboard. I have 3 motherboards that do it every time here. If it came back on eventualy it could very well be on its way out in the near future.
Posted on Jan 14, 2009
  • 51 Answers
Try removing the battery and unplugging the computer. Then put the battery back in and plug the computer in and turn it on.
Posted on Jan 08, 2009
IBM T22 laptop can't get it to start and not battery or charger.
What may have happened is that your power supply may have malfunctioned. I would try to plug another cable (new and functional) just to deny that this is the problem.
Nov 11, 2009 | IBM Thinkpad T22 Notebook
Can't power up. my IBM ThinkPad T22. I have the green light that indicates that it's charged up, however when I push the power button it just makes a flash and nothing happens.
If you only get a green light, try removing the battery first. If a laptop battery has gone bad, it will prevent a laptop from booting up.
Now, if removing the battery doesn't resolve your problem, check the laptop charger to make sure that the adapter has not malfunctioned.
If your fans are spinning, then the problem is probably the one listed below.
The transformer may not be converting the voltages properly.
Try these steps first. If it comes down to the internal transformer, then you have to contact IBM.
Aug 09, 2009 | IBM ThinkPad T22 2647 Notebook
IBM Think Pad TDD
reinstall the OS, but first back up you files. you can remove the HDD located at the bottom of the Laptop. buy a cheap 2.5 inch usb to ide/sata enclosure and place your hdd on it. use a PC to transfer your files. then format the HDD. reinstall the HDD to your laptop and install the OS.
Jul 06, 2009 | IBM ThinkPad T22 2647 Notebook
When on button pushed, brief lighting of hard drive light won't
Remove the battery, hard drive and memory chips then put the back nice and firmly. It often is the solution for such a problem. Otherwise the hard drive has bad sectors and cannot always read the operating system files to boot up.
IBM Think pad T22 problem
Hi
Check your laptop CPU fan is running if no replace it. Problem is because of over heating....
Thanks
Jul 10, 2008 | IBM ThinkPad T22 2647 Notebook
IBM Think Pad T22 auto -shut down a few minutes
Try running it without the battery. Sometimes an IBM battery can develop a short and cause this. If it still does it without the battery, I'm afraid it's the power management chip on the motherboard, and the motherboard will need to be replaced.
My T22 unable to start
Hi Yamato,
It is possible that the battery has been so depleted that it gobbles up all the power from the charger/adapter and leaves nothing for the laptop to use. Perhaps what you can do are:
1. try and charge the battery at least overnight with the laptop off;
2. use the adapter/charger only and remove the battery from the laptop.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | IBM ThinkPad T22 2647 Notebook
IBM T22 Battery won't charge & is not detected
Take it to a very good technician who will open it up and check a dry joint in the charging system.  Sometimes if you donot attend to it quickly you may find your T22 refusing to power at all with the AC Adaptor.  Delicate soldering may solve your problem.  Power may not be getting to the charging circuit and the battery thus it is totaly discharged.
Oct 24, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad R51 Notebook Logo
237 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
